Thread: Questions on DVD install
Results 1 to 6 of 6
  1. #1 Questions on DVD install
    Dec 2013
    laporte mn
    I have an aftermarket single din flip up DVD player that I want to put in my 04 comp g. My vehicle has a 6 disc CD player with the monsoon system and steering wheel controls
    My question is does anyone know the part numbers of the wiring harness I would need and also the piece for the steering wheel controls?
    Then I would like to know if there is any weird wiring I would need to do so the factory amp would work with the aftermarket DVD player?
    Thanks, let me know if u need anymore info
  2. #2 Re: Questions on DVD install
    Gmos-04
    04 Comp G.
  3. #3 Re: Questions on DVD install
    Dec 2013
    laporte mn
    Just that and the plastic piece is all I need?
  4. #4 Re: Questions on DVD install
    Gmos-04
    That's the harness you'll need to retain onstar and more important to keep the stock monsoon system working correct.
    Besides that you'll need a dash kit
    Antenna adapter
    Steering wheel module (to keep steering wheel controls) will depend on the brand and type of CD player that your throwing in there
    04 Comp G.
  5. #5 Re: Questions on DVD install
    Dec 2013
    laporte mn
    Why do I need to keep OnStar? What happens if I don't keep it?
  6. #6 Re: Questions on DVD install
    You don't have too.. But that's going to be kept with that harness... More importantly the harness allows you to keep using the stock monsoon amp
    04 Comp G.
  1. Intercooler install questions?
    By Ifryrice in forum 04+ Specifics
    Last Post: 06-26-2014, 01:09 PM
  2. Cam install questions
    By dbane in forum General Tech Discussion
    Last Post: 04-24-2014, 04:20 PM
  3. 3.4 pulley install questions
    By sarfitz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2014, 06:42 PM
  4. questions regarding cam install
    By hammer489 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2013, 07:33 AM
  5. ZZP MPS Install questions
    By Liquifire in forum General Tech Discussion
    Last Post: 10-13-2009, 02:21 PM
