Thread: Radio Wire Harness
Results 1 to 20 of 23
  1. #1 Radio Wire Harness
    Mar 2015
    Illinois
    Hi all!
    I joined this forum today just so I could ask this question. I've been searching the internet for a while and haven't found anything so hopefully you guys can help.
    I am wanting to install a new head unit (pioneer) in my 2008 Grand Prix. I have steering wheel controls, but no OnStar or Monsoon system. I've been searching high and low for a wire harness adapter to keep the factory wire harness in tact. Most of what I find is about $80 worth of an adapter for OnStar, which I don't need! Buttt..... I have found a couple kits on eBay.
    Both these kits have dash mounting kits and antenna adapters included.
    One kit has a simple wire harness adapter that only supports the audio coming from the radio. No warning chimes, no OnStar, no BS. $20
    The other kit has a simple wire harness adapter AND an interface for warning chimes. Again, no OnStar. $60
    So my biggest question is, what warning chimes run through the radio? Just OnStar chimes or everything? Because if the chimes aren't a big deal, Ill go with the cheaper unit. But if "warning chimes" means door, seatbelt, CEL chimes, etc., then ill get the more expensive one (because I want those features).
    Can anyone shed some light on this situation for me? Sorry for the long post, I just don't know what else to do! Any help is appreciated!
  2. #2 Re: Radio Wire Harness
    theres a adapter sold at crutchfields some one will pop in with the name and part #.
    but the moonson deal there, you'll need to run new speaker wires and install all new speakers, forget the factory amp too. its best to just by pass all the old crap. the speakers are a different ohm, so when you hook up the new hu to them the sound is far from right.
  3. #3 Re: Radio Wire Harness
    Mar 2015
    Illinois
    I don't have the monsoon so that won't be an issue. I'm not doing new speakers either. Just want a new head unit for Bluetooth reasons.
  4. #4 Re: Radio Wire Harness
    oh, i miss read once again lol i suck.......
    best buy should have a pig tail that fits into the factory radio plug, the wires on this plug are all labeled what they are for. makes hooking up a new hu easy. and saves the factory harness so you can go back to the stock radio if you ever wanted to.
  5. #5 Re: Radio Wire Harness
    Mar 2015
    Illinois
    Will the one from best buy still retain the OnStar and warning chimes, and cost me a fortune? Or will it just be like any normal radio harness? Because that's what im looking for. I don't need all the fancy interface connections.
  6. #6 Re: Radio Wire Harness
    the pug is just for the power and speaker wires.
    you'll need that adapter to keep all the chimes and steering wheel controls. if i knew the part # id tell ya. t theres guys who know more on that part. ive just seen it linked a 100 times in the past.
  7. #7 Re: Radio Wire Harness
    Mar 2015
    Illinois
    Do all the chimes run through the speakers? Like key, warning lights, seat belt, etc?
  8. #8 Re: Radio Wire Harness
    Oct 2011
    Toledo, OH
    Quote Originally Posted by grampete View Post
    Yes.
    7"
  9. #9 Re: Radio Wire Harness
    no idea where they come from, i do know a lot of stuff stops working when the factory radio is removed. the adapter fixes that.
  10. #10 Re: Radio Wire Harness
    Mar 2015
    Illinois
    Thanks for the help!
  11. #11 Re: Radio Wire Harness
    Mar 2013
    Canada
    When I did my radio install last year in my GP 2008, I got the expensive harness as all warnings/chimp go through your speakers.
  12. #12 Re: Radio Wire Harness
    GTP Level Member simbah's Avatar
    Lala land
    the harness required for the non Monsoon radio is the GMOS-01. You will also need another adapter for the steering wheel controls to function properly. Yes all chimes will be lost with cheap harness. Seat belts, door open key in ignition and all DIC warnings. SO if you want to keep the chimes then you will need the more expensive harness. On a side note you will lose the date function on the DIC, no way around it as the date is kept by the stock radio.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  13. #13 Re: Radio Wire Harness
    Mar 2015
    Illinois
    Quote Originally Posted by simbah View Post
    So no matter what harness I get, the date on the dash won't work?
  14. #14 Re: Radio Wire Harness
    Lala land
    That is correct sir.
  15. #15 Re: Radio Wire Harness
    Mar 2013
    Canada
    Trust me I thought I would miss the date on thr dash but I don't
  16. #16 Re: Radio Wire Harness
    Mar 2015
    Illinois
    Quote Originally Posted by ibra0078 View Post
    will everything else on the info center still work? like temp, compass, tire press, trip, blah blah blah? everything but the date and time?
  17. #17 Re: Radio Wire Harness
    Mar 2013
    Canada
    That is correct, what radio you putting in?
  18. #18 Re: Radio Wire Harness
    Mar 2015
    Illinois
    Thinking about a Pioneer FHX720BT. I have also looked at comparable units from Kenwood and JVC. Any recommendations? I am shooting for a factory (or at least as factory as possible) look. Looking to stay under $150.
  19. #19 Re: Radio Wire Harness
    I have this head unit and love it.
  20. #20 Re: Radio Wire Harness
    Mar 2013
    Canada
    I put in a avic x930bt in my other car and in my Grand prix believe it or not I put in this http://pages.ebay.com/link/?nav=item...640875&alt=web, it works really well and I didn't want to spend a lot on a HU but I wanted a navigation system. This system does more then my avic and if I would of bought a brand name with the same specs it would cost over 800 for sure.
  1. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  2. 04 GTP PCM and Wire harness
    By sholdwick in forum General Tech Discussion
    Last Post: 08-15-2012, 06:13 AM
  3. Radio Wire Harness
    By Russosaur in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2012, 07:40 PM
  4. abs wire harness?
    By mo1040 in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2011, 01:08 PM
  5. wire harness
    By BLKGP in forum Audio, Security & Visual Electronics
    Last Post: 10-25-2009, 11:38 AM
