Thread: Headlight Issue
Results 1 to 5 of 5
  1. #1 Headlight Issue
    Jersey
    Car is 97 gp se. I recently ordered a headlight assembly for the driver side and also ordered some ge nighthawk platinum bulbs. After installation, my passenger side has a better output of light while the driver side is somewhat scattered to the point of me not seeing the road. Ive tried using the adjustment screws but no luck. Any inputs?
  2. #2 Re: Headlight Issue
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    Is the the right bulb actually dim? if thats the case clean and check the connections. If the light is just not being distributed properly by the housing check to make sure that the bulb is properly installed... other than that idk. more info would be nice
    2000 GT Mods: HAI, 10.5mm wires, rebuilt 60k motor, ZZP stainless headers, magnaflow mufflers, fresh paint job,L-67 top swap, Ported SC...
  3. #3 Re: Headlight Issue
    Jersey
    Any extra info that i can think of is that i purchase the driver headlight from rockauto which is oem stock. The passenger side was purchased some time ago (new) from a junk yard. Its more slimmer and gives more of a direct beam pattern. Other than that im stumped!
  4. #4 Re: Headlight Issue
    Dec 2008
    Lawndale, CA
    Post some photos of them. I'm curious to see how the chrome reflectors look like.
  5. #5 Re: Headlight Issue
    Jersey
    Late update!!! : Sorry for bringing up old stuff but im took a look at my lights when i notice my driver side is darker on the inside than the passenger side smh. Im heading to the store now. All grounds have been cleaned with wire brush and wire brush with drill...this has to be it. Will get pics as soon as i install photobucket again
  1. HID Headlight Issue
    By wifflebiscuit in forum Audio, Security & Visual Electronics
    Last Post: 05-20-2013, 07:40 PM
  2. Headlight Issue
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 09-14-2011, 04:24 PM
  3. Please Help Headlight Issue!
    By happysol in forum General Tech Discussion
    Last Post: 03-17-2011, 10:54 AM
  4. GXP H.I.D. headlight issue
    By dacomeup411 in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2011, 03:41 PM
  5. Headlight Issue?
    By Klutch in forum Audio, Security & Visual Electronics
    Last Post: 01-02-2010, 05:21 PM
