Thread: Has anyone used the PAC RP5 GM11 adapter harness?
Results 21 to 40 of 59
  1. #21 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    GXP Level Member
    Mar 2015
    Tomball
    And this is on your 05' I take it? Is there a way to reprogram the module to make the steering wheel controls match up properly. I would see this as an issue.
    Jeff
  2. #22 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Aug 2015
    Virginia
    Yeah it can be reprogrammed, just don't have time to tear into it again just yet
    Sent from my iPod touch using Tapatalk
  3. #23 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    GXP Level Member
    Mar 2015
    Tomball
    Ok cool, I have been looking at doing my system and add an aftermarket radio and have heard conflicting reports.
    Jeff
  4. #24 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Aug 2015
    Virginia
    It comes with reprogramming instructions, the hardest part was soldering it to the wires of the HU
  5. #25 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    GXP Level Member
    Mar 2015
    Tomball
    I'll look it up online I have used a lot of PAC products in the past but got out of it just as CAN and most of the other hassles came on the market in new cars. Most I ever had to deal with was corvette's and having to take the radio apart and hide it under the seat to keep some functions working. I think that was in the mid-late 80's
    Jeff
  6. #26 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Aug 2015
    Virginia
    You lose your time and date on your DIC if that is something that you wanna keep
  7. #27 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    GXP Level Member
    Mar 2015
    Tomball
    Dammit, Well there went that one. Thanks for the update.
    Jeff
  8. #28 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Aug 2015
    Virginia
    Anytime, it doesn't bother me bc my unit shows it in the upper right hand corner of the radio
  9. #29 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    So i'm going to bring this thread back from the dead and share some issues I recently had. Like others have said I occasionally had my gauges go dead and would have to shut the car off and turn it back on to get them back. Had this happen 3 or 4 times since installing my new stereo in January. Thursday, I was coming back from a pretty long road trip and on the way back all of a sudden the radio stops, and smoke starts pouring out of the dash. I pull over (I was doing 80 on the interstate, so I was freaking out pretty bad) and shut it off and it's still smoking horribly out the dash and radio area with a plastic burning smell. Long story short, I think a wire shorted out from the PAC box and almost burnt down my car. I'll let the pictures do the talking.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  10. #30 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    GXP Level Member
    Mar 2015
    Tomball
    So was your error? I guess the radio and plug for the PAC were both melted? And am I correct to assume that the yellow wire is Constant hot?
    Jeff
  11. #31 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Jan 2013
    Raleigh, NC
    Yellow i believe is constant hot. Not sure how it would be my error as it was grounded good, and the yellow wasn't spliced or anything by me. It was just a plug and play thing on that side of it. Pretty sure it was just a bad part. I'm going to call the manufacturer tomorrow and see what the deal is.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
  12. #32 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Nov 2012
    Toronto, Ontario, Canada
    I had the gmos-01 die on me. Chimes would sound like a submarine and take forever to shut of and the gauges would go dead. Car was still running fine. Also the cruise control stopped working.
    When I disconnected the box and just wired the stereo to constant power everything started working again. Just gonna pick up a regular harness if I can find one. Not sure if the 04 plug is the same as the 08.
  13. #33 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Quote Originally Posted by chrias View Post
    Afaik you can't just hook it up with a normal harness.
  14. #34 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by chrsmi1 View Post
    by install error I meant like it rubbed through the insulation on the blue enclosure.
    did you get another one or what did you end up doing?
    as far as connecting it directly, Chrias I think your going to have issues.
  15. #35 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by J57ltr View Post
    Oh I meant to post an update. Sorry. I contacted their support and after a little runaround they sent me another module. I haven't installed it yet so nothing to report as far as it being ok or not.
    They did recommend that I have it professionally installed just to rule out any such issues being me, but I informed them that unless they were sending me a check to pay for that, I'll be installing it myself again.
    They did say they might have their engineering dept contact me about sending the defective unit back so they could go through it. Haven't heard from them about that yet though.
  16. #36 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    GXP Level Member
    Mar 2015
    Tomball
    As a manufacturer myself I would say send it in or contact them. I get so many people that don't get back to me then ***** that their having issues but never bother to call or even send an email.
    Jeff
  17. #37 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Jan 2013
    Raleigh, NC
    Jeff
    Yeah good advice. I'll send another email.
  18. #38 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Nov 2012
    The only issue I'm having right now is that I have to turn off the radio manually because the gmos-01 unit has been removed and the accessory wire on the head up it is connected to a constant 12v. I tried running the accessory wire to a switched 12v to the fuse box but the radio won't work.
  19. #39 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Jan 2013
    Kansas
    I just have a 2008 GP base model, w/o monsoon and w/o OnStar and Im using the GMOS-01 on my car and I suffer the same problem with my gauges shutting off for a second or two but they come back on. I thought it just happened when I use my usb on my radio to charge my phone, but yesterday it happened again and I wasn't even using my usb. Im just worried about the long term affects on my car since I barely put in my aftermarket radio like a week ago. Anyone find anything out about this?
  20. #40 Re: Has anyone used the PAC RP5 GM11 adapter harness?
    Nov 2012
    Check and see if your cruise control is working or not. If it isn't, it's the gmos-01 unit slowly failing. Another sign is the chimes take longer to turn off or it starts sounding like a submarine chime.
  1. Replies: 0
    Last Post: 01-15-2014, 02:27 PM
  2. WTB Gen 3 N* Adapter/IAT & MAF Harness/Cable Bracket
    By Blake71091 in forum Wanted To Buy - Parts
    Last Post: 01-11-2014, 12:42 AM
  3. Universal Head Unit Adapter, to a near flush adapter. [first writeup + pics]
    By Kolton Lock in forum How To Write-Ups/Tech Tips
    Last Post: 07-13-2012, 01:04 AM
  4. Harness/Adapter HU Quality
    By blackgagt1 in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2009, 07:37 PM
