I just bought 2 new key fobs from the dealer and went to reprogram them I closed all the doors pulled the mall pmg fuse inserted the key turned to accy let the bcm do its thing turned the key back to off and then back to accy opened one door and closed it the bcm did not chime pressed both the lock and unlock buttons on my key fob at the same time did not get any chime after seven seconds and nothing after 14 seconds repeated this many times and bcm just will not go into program mode need some help thanks
Mike
