Thread: Factory XM antenna
Results 1 to 4 of 4
  1. #1 Factory XM antenna
    I live here. DirtDog's Avatar
    Jun 2012
    So is it possible to use the factory XM antenna with an after market radio. I don't wanna have to add another one. Anyone know if there's any way to custom wire it to work? I have a head unit that's XM ready and the module and antenna that came with it for XM. Just don't want to add another antenna on the roof
  2. #2 Re: Factory XM antenna
    Oct 2011
    Toledo, OH
    Yes, the GM antenna should work if you already have the tuner module for your aftermarket radio. The factory antenna has to be unplugged from the silver box that is the factory XM tuner, which won't work with an aftermarket radio. The factory antenna should have a plastic shroud on the connector that needs to be popped off though.
    7"
  3. #3 Re: Factory XM antenna
    Dec 2016
    houston
    where is the silver box located
  4. #4 Re: Factory XM antenna
    Nov 2012
    Madison
    under the radio
  1. Replies: 23
    Last Post: 10-25-2015, 06:50 PM
  2. Euro style antenna / stock antenna delete
    By bandits grand prix in forum Visual/Body Modifications
    Last Post: 12-21-2014, 06:03 PM
  3. Full size female antenna to mini male antenna adaper?
    By iowagtp in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2012, 02:52 PM
