Thread: Bluetooth Dongle Adapter for my aftermarket HU
Results 1 to 14 of 14
  1. #1 Bluetooth Dongle Adapter for my aftermarket HU
    Topeka, KS
    Wondering if I should give this a try or not. The current 3.25mm headphone to rca cable going into the back of my headunit has a short. Near the plug that hooks into my phone. My HU is about 8 years old and doesn't have bluetooth. So I thought this might be a nicer solution.
    http://www.amazon.com/Fusion-MS-BT10...th+adapter+rca
    Inputs, thoughts, and suggestions wanted!
    Thanks,
    Ryno
  2. #2 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Ryan.. It's a cable or it's a jack?
    If it's a cable you have plugged into a jack, we'll make you change just the cable. If it's a wire going into the head unit..you could pop it open and solder a new one in.
  3. #3 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Topeka, KS
    Basically it's a rca cable plugged into a aux rca jack in the back of my radio. The side that plugs into my phone is the standard headphone plug where the issue resides. Yes I've though about cutting the plug off and soldering on a new one.
    Sent from my SCH-I545 using Tapatalk
  4. #4 Re: Bluetooth Dongle Adapter for my aftermarket HU
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I have this and it works really well. Hold a charge for a long time and uses the same cable as a cell phone so it's not a pain to charge. Reading the reviews for the one you linked sounds like a pain because it's doesn't automatically reconnect.
    http://www.amazon.com/Motorola-Roads...+speaker+phone
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  5. #5 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Topeka, KS
    The one I listed is more of an input to my radio vs just a Bluetooth speaker
  6. #6 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Buffalo, NY
    Ya, was just throwing it out there as something to consider. I personally like something like that better but the idea of what you posted being hidden is nice. The Motorola thing though can go through the headunit into the car speakers.
  7. #7 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Topeka, KS
    Cool. I'd probably have to hardwire that as well though
  8. #8 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Buffalo, NY
    No wiring need for it. It tunes into a radio station so all you have to do is save the station to a preset to use it everytime you get a call. Or you can just let it go through the things speaker which is what i do.
  9. #9 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Topeka, KS
    Hmm... I'll look into it
  10. #10 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Topeka, KS
    Got my Moto Bluetooth today. Sending it back. I got it on a scratch and dent on Amazon. The FM modulator has alot of static and the music fades in and out. Cool device, sad it didn't work really.
  11. #11 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Buffalo, NY
    Are you going to buy a brand new one or go with something else?
  12. #12 Re: Bluetooth Dongle Adapter for my aftermarket HU
    GTP Level Member
    springfield IL
    http://www.soundmanca.com/products/bluetooth-chip
    this is what ive been using for past couple months... LOVE IT!!
  13. #13 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Topeka, KS
    Not sure at the moment. That Motorola was cool. I might try the Jabra version.
  14. #14 Re: Bluetooth Dongle Adapter for my aftermarket HU
    Topeka, KS
    Anyone tried the Jabra? It seems both have contradicting reviews. Some say the FM modulation sucks streaming and others seem to think it's OK.
  1. Security light came on when I plugged in bluetooth obd2 adapter.
    By iowagtp in forum General Tech Discussion
    Last Post: 09-23-2013, 11:53 PM
  2. bluetooth obd 2 adapter and torquepro ( obd 2 & car ) questions
    By comatoast in forum General Tech Discussion
    Last Post: 07-24-2013, 01:05 PM
  3. elm327 bluetooth adapter?
    By des19 in forum General Tech Discussion
    Last Post: 09-08-2012, 09:16 PM
  4. Reviews on the PLX Kiwi Bluetooth adapter?
    By Kolton Lock in forum Off Topic Discussion
    Last Post: 08-03-2012, 04:33 PM
