Thread: New head unit install
Results 1 to 4 of 4
tachasmo New head unit install 08-22-2014, 03:00 PM
simbah Re: New head unit install 08-22-2014, 04:21 PM
douger Re: New head unit install 08-22-2014, 07:43 PM
tachasmo Re: New head unit install 08-23-2014, 10:44 AM
  1. #1 New head unit install
    Aug 2012
    Iowa
    Hey guys I have an 05 GTP without the Monsoon system. I'm looking at buying a PIONEER AVHX5600BHS and installing it myself. I've installed plenty of new head units in vehicles before, but never in a GM vehicle. I'm just wondering what wiring harnesses I need to maintain my vehicle chimes as well as the steering wheel controls. I don't really care about the On Star because I have never used it and never plan on it either. Thanks in advance for your help.
  2. #2 Re: New head unit install
    GTP Level Member simbah's Avatar
    Lala land
    GMOS-01 wiring harnessand either
    PAC SWI-PSv1 or
    Axxess ASWC-1
    for steering wheel control
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: New head unit install
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by simbah View Post
    PAC SWI-PSv1 or
    Axxess ASWC-1
    What he said.
    Radios are integrated with the BCM. There have been reports of problems with the security system without a module like the GMOS-01. It also makes it easier to install. There's no hacking of the factory harness, so if you want to put the factory radio back it, it's a matter of pulling out your modules and plugging the radio back in.
    You'll also need a mounting bracket. This is the one you'll need if that new head unit is the double DIN radio I think it is.
    BTW... you'll lose the date function of your DIC when you remove the factory radio.
  4. #4 Re: New head unit install
    Aug 2012
    Iowa
    Thanks for the info. I never use the date function anyways so that won't be a big deal, but it is nice to know that it will be unusable before I start doing is instead of finding out after I've done the install and thinking I did something wrong. I also forgot to mention that I have a Viper 5704 remote start/alarm system. Does that change anything or will it add complications to the install at all? Also, would you recommend one of the harnesses over the other for the steering wheel control, or are they both pretty much the same?
  1. 01 New Head Unit Install
    By stuntsiderida100 in forum Audio, Security & Visual Electronics
    Last Post: 06-26-2013, 04:50 PM
  2. 2003 Head Unit install
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 06-24-2013, 08:07 PM
  3. New Head Unit Install
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 12-02-2012, 09:14 AM
  4. No audio after head unit install
    By rah575554eg in forum Audio, Security & Visual Electronics
    Last Post: 03-19-2012, 02:17 PM
  5. 04+ head unit install
    By brian76708 in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2011, 11:00 AM
