Thread: 04+ HUD in 97-03
Results 1 to 8 of 8
  1. #1 04+ HUD in 97-03
    Sep 2013
    Goldsboro, NC
    Will the HUD work on a 97-03 body style. My GXP is pretty much totaled out and I'm thinking about pulling everything out of it that I can and swap over to my 00 GTP daily driver.
    Thanks in advance,
    Tate
  2. #2 Re: 04+ HUD in 97-03
    Probably..but would probably be a easier swap just to grab one from the 97-03.
    Swap the seats from the GXP to the 97-03
    Also swap the rims and struts as well as the brakes.
    04 Comp G.
  3. #3 Re: 04+ HUD in 97-03
    Sep 2013
    Goldsboro, NC
    My 00 has HUD just the 04+ is so much nicer, didn't know if it would work or not. Yeah, thinking about seats, struts w/ SSC springs, rims/tires and brakes. Then just need to find out what to do with the rest of the car. I guess junk it.
    Tate
  4. #4 Re: 04+ HUD in 97-03
    Oct 2011
    Toledo, OH
    Can you swap the engines? That would be badass.
    7"
  5. #5 Re: 04+ HUD in 97-03
    Part out the rest and scrap it
    04 Comp G.
  6. #6 Re: 04+ HUD in 97-03
    Dec 2012
    troll land
    Find out if 04 hud is 4000 ppm
  7. #7 Re: 04+ HUD in 97-03
    Arizona
    I want your gauge cluster and struts if red justnhappens to be in a place with bad reception when you sell them..
    Oh and also the DIC as well.
  8. #8 Re: 04+ HUD in 97-03
    Hahahaha
    04 Comp G.
