Thread: HO alternator
Results 1 to 18 of 18
  1. #1 HO alternator
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Would like to know how hard it is to swap out the stock alternator with a HO one.
    Do I need a different belt for that?
    Ive done part of the big 3, the wiring, need the alternator and doing battery sooner or later.
    Running two type r's at 2200 watt, and I have bose so the watts are going up.
    01 GT with 54k on the odometer.
  2. #2 Re: HO alternator
    Pennsylvania, USA
    A properly built HO alternator will bolt right up, possibly with an adapter bracket, and will use the stock belt size. That is if it's not just an alternator with an under drive pulley. I have one from DC Power I got about 3 years ago, and it came with all the necessary hardware, took no longer than installing the stock alternator.
    Be prepared to spend some money though, well built HO alternators that will last can be a bit pricey.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  3. #3 Re: HO alternator
    Aug 2012
    Brainerd, MN
    what company is a good one to get one that's built right? price is not a matter to me, I just want to get everything fixed before something goes wrong with the system in the car. Dc power?
  4. #4 Re: HO alternator
    Aug 2012
    Brainerd, MN
    anybody know what deep cell battery brand I need to get? I head optima, odessey?
  5. #5 Re: HO alternator
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Are you going to add a second battery or just upgrade your existing? Might want to hit up audio forums for recommendations.
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: HO alternator
    Jun 2013
    Tucson, AZ
    mech man alternators are serious **** but also for serious cash
  7. #7 Re: HO alternator
    Feb 2010
    TN
    Every now and then I come across one in the Junkyard on Police cruisers I keeps wonder if there would be a point in swapping since I do not have a lot of electronics my car
  8. #8 Re: HO alternator
    Not for you Logan.
  9. #9 Re: HO alternator
    Feb 2010
    TN
    Thanks Bill that's what I thought
  10. #10 Re: HO alternator
    Aug 2012
    Brainerd, MN
    I ended up buying a 220 amp DB electrical for 280$. Im looking into if I need a new battery right away or not, its a interstate. I know I need a deep cell, been looking at optima, odessey ect.
  11. #11 Re: HO alternator
    GTP Level Member
    springfield IL
    What amp(s) are you even running??
  12. #12 Re: HO alternator
    Aug 2012
    Brainerd, MN
    Quote Originally Posted by tc300 View Post
    got my factory bose amp, 2200 hifonics amp @ 1 ohm so pushing the straight 2200 watts. I could tell it started hard after I was bumping and turned the car off for a couple minutes, then took a couple seconds to start
  13. #13 Re: HO alternator
    GTP Level Member
    springfield IL
    Quote Originally Posted by Mirraco View Post
    That amp isn't doing 2200 watts.. Don't waste your money on alternator, get an good extra battery and 1/0 OFC cable...
  14. #14 Re: HO alternator
    Antioch, IL
    Just because the amp says 2200 doesnt mean its pulling it, maybe at 14.4v, if your straining the system your under 12v. I can hit 11.6 all day long when I crank it. Probably running 4ga power wire aint ya
    2009 Challenger SRT8
    Expert at being gay.
  15. #15 Re: HO alternator
    Aug 2012
    Brainerd, MN
    Quote Originally Posted by ITHURTZ View Post
    i put a 0 gauge kit on it.
  16. #16 Re: HO alternator
    Dec 2012
    troll land
    Im rockin an optima
  17. #17 Re: HO alternator
    Nov 2009
    PACNW
    I run Optima batteries in all of my vehicles. The Pontiac has had an Optima almost as long as I have owned it, the factory battery died the first year I owned the car. If you get the Optima red battery, you can tap into the side connectors for amps and accessories and use the top connectors for the stock car electrical.
  18. #18 Re: HO alternator
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    db electric, bad choice. Talking from experiance here, mine only lasted 1.5 years and almost left me stranded. Currently have a Ohio Gen alt for a different 3.8, works well drop down to 12.4 or so at full tilt on my old batteries.
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  1. If its not the alternator, what is it?
    By Vitality62 in forum General Tech Discussion
    Last Post: 09-25-2010, 12:24 AM
  2. alternator
    By Slueth66 in forum General Tech Discussion
    Last Post: 01-29-2009, 10:05 AM
  3. is it my alternator?
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 05:38 PM
