Thread: Key and button under dash?
Results 1 to 16 of 16
  1. #1 Key and button under dash?
    SE Level Member duswickware's Avatar
    Jan 2014
    mansfield, ohio
    Looking under my dash today and noticed there is a key with a grey wire wrapped around it not really sure of the purpose but dont wanna take it off and car not start and a couple layers of electrical tape wrapped around it, also found a little black button( it looks like) hanging down....assuming this is something to do with the security system but not sure if it should be hanging or strapped to something. Any idea what's going on here?
  2. #2 Re: Key and button under dash?
    Prolly a bomb or something.
    But really we don't have idea either, likely the owner before installed something either with a aftermarket security system or had something else that needed a power switch.
  3. #3 Re: Key and button under dash?
    Oct 2011
    Toledo, OH
    Yep, probably a bomb.
    But maybe only a valet key/button they didn't want removed.
    7"
  4. #4 Re: Key and button under dash?
    Pics?
  5. #5 Re: Key and button under dash?
    leave it there, sounds like someone put a chipped key in there so they could use un chipped keys to run the car. its a by pass mod ive seen if you dont want to pay for keys with chips in them.
  6. #6 Re: Key and button under dash?
    Jan 2014
    mansfield, ohio
    That's what I thought it was with the key....why couldn't I use the key that's down there for the car if it has chip?
  7. #7 Re: Key and button under dash?
    you should be able to use it. but if the rest of the keys you have are not chipped they will no longer work.
    that button could be the release button too. the one you'd push to turn the key back to off if the battery was dead, or if the shiftier wire broke. so that also me be rigged up.
  8. #8 Re: Key and button under dash?
    Jan 2014
    mansfield, ohio
  9. #9 Re: Key and button under dash?
    Jan 2014
    mansfield, ohio
    Prolly jus leav the key there....works fine so not gonn mess woth it yet.
  10. #10 Re: Key and button under dash?
    link dont work. copy the direct link, then past it into the image icon 3 rd from the right in the reply box.
  11. #11 Re: Key and button under dash?
    Jan 2014
    mansfield, ohio
  12. #12 Re: Key and button under dash?
    Aren't the keys with chips in them like 3 bucks on eBay?
    Sent from A Galaxy Far Far Away........
  13. #13 Re: Key and button under dash?
    depends on the year how much. most are like 12 bucks tho. mine was. (first thing i bought for my car, it came with one set) newer maybe like 20 to 30 each. then theres if its a newer car the dealer needs to program new keys iirc.
  14. #14 Re: Key and button under dash?
    Once I put a multimeter to mine and got the resistance value...it took me minutes to solder the proper values right onto the BCM wiring. Unplugged the column connector and ... yeah. Never have a problem.
  15. #15 Re: Key and button under dash?
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    Probably an aftermarket Remote Start bypass. Look under the dash for more non-stock wiring, and locate the remote start brain. If you don't have a remote for it, you can probably track one down.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  16. #16 Re: Key and button under dash?
    GT Level Member glendayle's Avatar
    Salt Lake City
    When I bought my auto start, that is all they did. Put together a few resisters that fell in the correct range.
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  1. 3 button DIC to 5 button swap questions
    By pontiacguy86 in forum General Tech Discussion
    Last Post: 10-15-2016, 01:49 PM
  2. 04+ 3 button to 5 button upgrade
    By Mad Monkey in forum How To Write-Ups/Tech Tips
    Last Post: 08-30-2016, 05:00 PM
  3. Stock intake w/ K&N, HUD dash bezel, front dash bezel
    By Swole in forum For Sale - Parts
    Last Post: 03-21-2014, 10:28 PM
