Thread: Door locks on 2002 coup
Results 1 to 7 of 7
  1. #1 Door locks on 2002 coup
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    I have a problem with my door locks, when I go to lock the doors using the key fob, the passenger side locks but the drivers side does not. The alarm on the car even activates when I open the drivers side door with it being unlocked. Any ides would be appreciated. I am thinking its the drivers side door lock that needs replaced.
  2. #2 Re: Door locks on 2002 coup
    the lock actuator took a dump if you dont hear it clicking, or a wire got pinched maybe.
    if you hear it try to work, then maybe the linkage popped off. you'll have to take a look inside the door to know better.
  3. #3 Re: Door locks on 2002 coup
    Oct 2012
    Illinois
    Ok, this is what I did. I got in the car and locked the doors with the switch and only the passenger door locked. I locked the drivers door manually and pressed the unlock button on the door and they both unlocked and it acts the same with the key fob. Unlocking the doors work and locking the doors either with the key fob or door does not lock the drivers side. I here something like its trying to lock the drivers door
  4. #4 Re: Door locks on 2002 coup
    actuator or linkage failure. take the door skin off the inside of the door, its a few screws and tree clips around the sides and bottom.
    once you can see inside work the button for the locks see whats going on.
  5. #5 Re: Door locks on 2002 coup
    Oct 2012
    Illinois
    Found the problem by accident, I was going the take the car to the car wash and could not find the keys. I got my spare set of keys and the key fob worked fine regarding the locks. Something must be wrong with the other so I will have to look in to getting a new one.
  6. #6 Re: Door locks on 2002 coup
    open the case, with a Q tip and some rubbing alcohol clean the circuit board and the buttons on the inside of the fob case.
    put it back together and see if it works now. if the Q tips are filth dirty after wiping the parts clean i bet it works like a charm.
    if it dont work you can glue tin foil to the buttons so they make better contact or use foil tape and a paper hole puncher to make nice little circles to stick on the buttons.
    theres a few how to's ive done them all.
    as well as bought new fob button pad for like 5 bucks off ebay.
    the fob buttons have metallic paint on them so when they hit the wires of the board it makes contact. the foil fixes the worn off paint.
  7. #7 Re: Door locks on 2002 coup
    Oct 2012
    Illinois
    Will do, thanks. Keep you updated
  1. Door Locks
    By Jakescoots in forum Visual/Body Modifications
    Last Post: 05-03-2011, 06:38 PM
  2. Door locks
    By shawnschuldt in forum General Tech Discussion
    Last Post: 04-26-2011, 02:58 PM
  3. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
