Thread: Front speakers no longer working
Results 1 to 5 of 5
  1. #1 Front speakers no longer working
    Oct 2012
    Canada
    The only sound im getting out of the front speakers is coming from the small tweeter in the drivers side door. The rear speakers work fine (And yes i checked the balance and fade knobs, there in the right position, i even tried playing with them to find out which speakers were working).
    So what could be the issue here? where do i start?
    Note: I did just have the infamous water leak issue on the passenger side of the car and im still getting water in on the drivers side. Could this have something to do with it?
    Help!!
    Edit: I have the bose system in the car and i also get random static at times but only through the radio so i think thats an antenna issue. Listening to a cd there is no static but the front speakers still dont work no matter what im listening too.
    99 GTP
  2. #2 Re: Front speakers no longer working
    Feb 2014
    Grand Forks, North Dakota
    It could be a handful of things that are the problem. Water could have shorted both the front speakers out. They both could have just died at the same time (maybe not from the water issue). Moisture or water could have done something to the radio wire harness that only effected the the front left and right speakers. Trying testing the connection with another speaker, one that you know works. If it works then it was the speakers. Remove the door panels and test with a voltage meter.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  3. #3 Re: Front speakers no longer working
    Nov 2011
    NY
    Water in passenger floor is a $3 fix, get to it!
    I'd say the water got somewhere it shouldn't have, maybe speakers, maybe head unit... It could be totally unrelated and just death by old age! Lol
  4. #4 Re: Front speakers no longer working
    Oct 2012
    Canada
    I already picked up the replacement part to fix the water leak onto the passenger floor (cost me $8). I still have an issue with water getting in on the drivers side though. Could be HVAC drain clogged, could also be my windshield leaking. Gonna look into the speaker issue this weekend.
  5. #5 Re: Front speakers no longer working
    May 2014
    Flint
    Anyone update johnny? Just bought a gp and fronts are dead.....
  1. remote start on 2007 gxp (factory) no longer working
    By painthorsemoe in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2013, 11:38 AM
  2. pioneer ts G1642R speakers into front doors speakers?
    By thomasd2010 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2013, 10:16 AM
  3. 1998 Grand Prix GTP climate control and mpg display no longer working
    By Unknown in forum General Grand Prix Discussion
    Last Post: 11-14-2012, 10:04 AM
  4. Is there a rubbing issue with ZZP Longer front brake lines?
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 04-19-2012, 12:41 PM
  5. HUD No Longer Working
    By jwjones in forum General Tech Discussion
    Last Post: 03-01-2012, 08:58 PM
