Thread: The ultimate in-your-face lights and LED FAQ!
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #1 Re: The ultimate in-your-face lights and LED FAQ!
    Feb 2013
    Missouri
    Well thats fixed. Now whenever the blinkers are on the climate control and gear indicator dim opposite the blinker. I hate GM wiring.
  2. #2 Re: The ultimate in-your-face lights and LED FAQ!
    Jul 2010
    Coquitlam,BC,Canada
    Glad I gave up on fixing mine.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: The ultimate in-your-face lights and LED FAQ!
    Feb 2013
    Missouri
    I have it figured out, well whats going on at least. The brown parking light wire is back feeding the grey\black wire. The grey\black wire is a wire that gets +12v whenever the parking lights are on to dim the various things in the car (HVAC, etc.) If I could modify the headlight switch to have the grey\black wire disconnected from the brown wire whenever the parking lights are off, I'll be in business. I think. With this problem at least.
  4. #4 Re: The ultimate in-your-face lights and LED FAQ!
    Feb 2013
    Missouri
    I think I got it. I have to tap the grey\black wire into the headlight wire instead of the parking light wire. It'll act a bit weird if I turn the parking lights on during the day, everything but the HVAC and the PRND321 indicator will dim, then when the headlights turn on those 2 will dim as well. Since I use my automatic lights, everything will dim as usual at night. I still haven't put in the damned EP28 flasher. I'm kinda worried about some stupid bull **** coming up with that.
    So far I've had to put a diode on the blue wire for the 31XXA bulbs up front, load resistors on the brown wire for the 194s up front, and and move this grey\black wire to the yellow wire on the headlight switch. Not all that hard, but figuring out what I that I needed to do those 3 things has been a *****.
    Cancel that. The 194s don't blink unless the parking lights are on.
  5. #5 Re: The ultimate in-your-face lights and LED FAQ!
    Apr 2014
    Ontario
    How do you get the map light so bright
  6. #6 Re: The ultimate in-your-face lights and LED FAQ!
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by GPfoSHEEZY View Post
    Put LED's in it.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: The ultimate in-your-face lights and LED FAQ!
    Apr 2014
    Ontario
    Quote Originally Posted by Bronco Boy View Post
    Put LED's in it.
    Yeah but like, it looks like theres 2 led panels in the single dome light. I have a single lled panel with 6 on it and its not cutting it.
  8. #8 Re: The ultimate in-your-face lights and LED FAQ!
    Jul 2010
    Coquitlam,BC,Canada
    Did you not change both lights? Map light has two lights in it....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: The ultimate in-your-face lights and LED FAQ!
    Dec 2012
    Where 4T65E's were born
    The ebay 2 strip LEDs I put in mine are bright, way brighter than stock. They had one's with more lights too lol
    Sold.
  10. #10 Re: The ultimate in-your-face lights and LED FAQ!
    SE Level Member Metal Links's Avatar
    Dec 2013
    NJ
    Do the LED reverse light perform any better than stock for 04+? The stock ones leave much to desire.
  11. #11 Re: The ultimate in-your-face lights and LED FAQ!
    Nov 2018
    OH
    Little issue going on and I have searched and understand this is common. I installed a LED all in one conversion kit for the low beams. Now the fog lights don’t work. I understand it’s something to do with the current draw. What is the best way to fix this? I have seen solutions from reroute to the parking lights and also resistors. Any suggestions?
  1. *** Ultimate HID thread ***
    By BackInBlack in forum Visual/Body Modifications
    Last Post: 04-07-2017, 09:59 AM
  2. projector ultimate fix...
    Last Post: 02-27-2012, 01:36 AM
  3. Ultimate sleeper??
    By bandits grand prix in forum Off Topic Discussion
    Last Post: 07-04-2011, 05:47 PM
  4. Ultimate Fighter
    By KawaFord in forum Off Topic Discussion
    Last Post: 06-19-2010, 11:46 PM
