Thread: wiring diagram 97-03 stereo with bose where there few wires do?
Results 1 to 20 of 28
  1. #1 wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
  2. #2 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    ttt
  3. #3 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
  4. #4 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Quote Originally Posted by douger View Post
    that link got the main harness but this is the diagram i need the plug for
    http://i597.photobucket.com/albums/t...G_00000123.jpg
    Pink is radio on i believe
    locations of GRN, the BLU and orange/black tracer
    are all 3 heading to the amp? according to that 2nd diagram there is a dk blu for RR low audio+ and a dk GRN for LF low audio - but nowhere for a orange wire?
  5. #5 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    Quote Originally Posted by wild2crazy View Post
    If I recall, orange is almost always 12 volt positive for audio equipment.
  6. #6 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    looked up some documents from 12volt.com from alarm systems under that heading they had the pink as ignition which would work for the amp and they also had a orange/black tracer for factory disarm. The plain orange is 12volt all time which is in the larger stereo harness. and 12volts wiring diagrams for the radios are not matching the colours from the factory they need to update a little.
    shows right rear having a blu/wht when its black from factory.
  7. #7 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    i would love to know where people on here are getting the wiring schematics for the radios? theyre at least correct other than that missing 4wire into radio and its functions
  8. #8 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    they sell pig tails that plug into the factory harness, the new wires are all labeled.
  9. #9 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    yeah thats the one in my picture but thats not the factory 9 pin for the bose system . loooking at and integration harness like this one from PAC http://www.pac-audio.com/productDeta...?ProductId=168
    only harness that uses the 9 pin with the 21pin harness
  10. #10 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Just as a heads up you do not need that harness. Just hook the remote turn on lead from your aftermarket radio to the pink wire in the amp harness.
  11. #11 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Quote Originally Posted by slick2500 View Post
    Yes and no you need that pink wire from the cd changer harness(9pin) Tried it without it and it did not work any speaker without that pink wire so those bose amps control every speaker in the car. Hooked up that pink wire to the pioneer and everything is mint now. Just finishing up the fiberglass work on the dash/hvac board then i'll post up the pics.
    Douger couple more wires i need locations for and where to grab them i need the
    (Parking Brake + wire) what colour would that be and would it be in the bcm harness/connector?
    (reverse light + on wire) same what colour and wheres the good location for it. Its for the back up camera for the head unit.
  12. #12 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    Aren't you using a GMOS or similar adapter? If so they're both part of the serial data stream and there'll be a wire for each.
    I'd be leery of tapping into BCM outputs. But here are some workarounds you might consider:
    On the internet, you can usually find a method of bypassing the parking brake lockout. Sometimes it's as simple as grounding that wire. Other times, it's more complicated.
    For the reverse input, you may need to go directly to the PRNDL switch on the transmission. It's underneath the selector lever.
    BTW, I powered my camera by tapping into the reverse lights circuit and mounted it centered on the bottom of the reverse/tag lamp assembly. I'm not sure how you could mount yours, and you'd still need to solve your reverse input dilemma.
    I'm adverse to tapping into wires on these newer cars with serial data. I'd rather not introduce trouble if I don't have to.
  13. #13 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    I still have access to GM Service Information, so here goes:
    On your 9 pin connector, that is called connector C3 for the radio. The GM part number is 12064980
    Pin 7 - PNK - Radio on signal
    Pins 8 and 9 - Not used
    Pin 10 - LT GRN - Remote playback device right audio signal
    Pin 11 - ORG/BLK - Remote playback device left audio signal
    Pin 12 - LT BLU - Remote playback device common signal
    Pins 13-15 - Not used
    Facing the business end of the connector, pin 7 is at the right and pin 15 is at the left.
  14. #14 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Ahhh makes sense now that 9 pin connector is for the factory Cd 12disc changer that my car does not have so i'am going to assume that the other end of that 9pin connector is in the trunk tied up and was not for the factory bose system at all. good link on it here
    http://impalahq.naioa.com/HowTo/Mystery_connector.html
    Thanks again douger
  15. #15 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    6 GRY/BLK 308 Parklamp Switch Signal - ON
    that's the grey guy i was looking for. That saves me so much time looking.
    So lucky you got access to those gm diagrams id be on it all day looking at those.
    This info should be a sticky i bet alot of people would be needing this info later on the 97-03s
    Thanks buddy.
  16. #16 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    Thanks buddy.
    I don't have a connector view of the steering wheel control. That's part of the serial data setup.
  17. #17 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Yeah probably sends signal voltages for the commands probably exactly how a steering wheel adapter does. Very nice. I see now why when hooking up the aftermarket harness you lose the 2 top speakers in the back of the bose system. 2rear tweeter are only out the 24 amp side
  18. #18 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Aug 2012
    Fort Wayne
    That's different from the Monsoon system I had in my 2005. The amp apparently functioned as the crossover for those tweeters and the ones in the front doors.
    I've pretty much ditched the Monsoon. It runs the center dash speaker now. That's where I get my chimes. The rest of the speakers are driven by a Pioneer amp and a Bazooka tube sub. I can't tell you how much happier I am now with the results.
  19. #19 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Oh you got them 100% right on Douger
  20. #20 Re: wiring diagram 97-03 stereo with bose where there few wires do?
    Oct 2013
    Toronto
    Dude you are the BOMB!!!!!!!!! that's exactly what i was asking for.
    Ok how about that above picture of the 21 pin connect harness its got Black/white tracer the blue and the green.
    would those 3 that be for the steering wheel controls. and the wire GRY/black tracer in pin slot 5 of the 21pin harness.
  1. Pioneer AVH-P2400BT?
    By Kilroy in forum Audio, Security & Visual Electronics
    Last Post: 04-06-2013, 10:50 AM
  2. Pioneer's 2000 Navy Blue GTP.
    By PioneerGTP in forum Members Rides
    Last Post: 01-07-2013, 05:32 PM
