Thread: found these for the rear deck 2004 gtp...
Results 1 to 5 of 5
  1. #1 found these for the rear deck 2004 gtp...
    Sep 2013
    Frederick,MD
    Infinity Reference 9632cf 6x9-Inch, 300-Watt High Performance Two-Way Loudspeaker (Pair)
    • 6 x 9-inch two-way loudspeaker with 300 Watts peak power handling and 2 Ohm impedance
    • Plus One woofer cones and durable rubber surrounds for increased bass output and higher efficiency
    • Edge-driven textile dome tweeters for increased power handling and reduced distortion at high output levels
    • Tweeter level adjustment and swivel positioning for optimizing sound and stereo image
    • One-year warranty
    • One-year warranty
    couldnt get a pic but they are 2 ohm...
  2. #2 Re: found these for the rear deck 2004 gtp...
    6x9s suck get a 6.5 mid bass driver or a 8inch sub is what ive always wanted to try. Just make a MDF ring to mount it. Im sure an 8 wouldn't be hard to fit unless its got a massive basket or magnet on it. 6x9s meh there are better options.....
  3. #3 Re: found these for the rear deck 2004 gtp...
    Sep 2013
    Frederick,MD
    ive done that once in a thunderbird,put a 8" sub in place of a 6.5 with some slight mods.sounded pretty good too,i was looking for a {quick} drop in replacement this time though.thee seem to be the only ones that get a few good ratings,everythung else dont look like they do to well
  4. #4 Re: found these for the rear deck 2004 gtp...
    Nov 2011
    Omaha, NE
    Get the kappas....they are waaay better. Sound even nicer with a little amp hooked up
  5. #5 Re: found these for the rear deck 2004 gtp...
    Sep 2013
    Frederick,MD
    i found a 6x9 kappa for around $100..didnt say whether it was 2 ohm or not though...im still doing some research
  1. 5.25s in rear deck
    By XxMbXx in forum Audio, Security & Visual Electronics
    Last Post: 09-13-2013, 09:03 PM
  2. rear deck
    By ssiebor14 in forum Audio, Security & Visual Electronics
    Last Post: 07-27-2013, 11:26 PM
  3. rear deck
    By jhintz in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2013, 02:36 PM
  4. Rear Deck Speakers
    By dert in forum Audio, Security & Visual Electronics
    Last Post: 10-09-2012, 08:56 AM
  5. Help with rear deck rattle
    By accuab in forum Audio, Security & Visual Electronics
    Last Post: 01-09-2012, 01:44 PM
