Thread: High Beams
Results 1 to 15 of 15
2coolit High Beams 11-28-2013, 12:02 PM
Scottydoggs Re: High Beams 11-28-2013, 12:24 PM
2coolit Re: High Beams 11-29-2013, 05:34 PM
Scottydoggs Re: High Beams 11-29-2013, 06:37 PM
2coolit Re: High Beams 12-05-2013, 11:51 AM
2007GPGTSC Re: High Beams 12-05-2013, 11:54 AM
2coolit Re: High Beams 12-05-2013, 11:56 AM
2007GPGTSC Re: High Beams 12-05-2013, 11:56 AM
2coolit Re: High Beams 12-05-2013, 12:00 PM
2007GPGTSC Re: High Beams 12-05-2013, 12:05 PM
2007GPGTSC Re: High Beams 12-05-2013, 12:04 PM
Scottydoggs Re: High Beams 12-05-2013, 12:06 PM
2coolit Re: High Beams 12-17-2013, 10:53 AM
2coolit Re: High Beams 12-17-2013, 10:51 AM
2007GPGTSC Re: High Beams 12-17-2013, 11:07 AM
  1. #1 High Beams
    Jan 2013
    Kansas
    So the other day I noticed that at night if I used the turn signal to turn right my high beams came on. If i moved the switch a bit back it went back to low beams, but then if I pushed it up to turn right again the high beams came on again. I noticed if i do it real slow and gentally it doesnt activate the high beams. And as far as ive noticed it only happens when i use the switch to turn to the right, not to the left. What gives??????
  2. #2 Re: High Beams
    sounds like its time for a new multi switch there. the stick and the guts behind the plastic in the column.
  3. #3 Re: High Beams
    Jan 2013
    Kansas
    Damn... Is it possible to swap it out yourself or do you got to take it in and get it done?
  4. #4 Re: High Beams
    you can do it yourself. you need a small torx bit to get the plastic off the column, then take the plastic and the steel part under the column off, follow the multi switch harness under the dash, theres a small bolt in the middle of the plug, then take the plug out, and put the new harness in place.
    this is a ignition harness swap how too. but the plug you need to change is part of this plug, and you need to take all the same stuff off to get the switch out.
    http://www.sparkys-answers.com/2009/...-changing.html
  5. #5 Re: High Beams
    Jan 2013
    Kansas
    Alright thanks, i will have to try that once i can get a new switch. Is it the same for like 04+? cuz i have an 08; failed to mention that.
  6. #6 Re: High Beams
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    ^^mine does the same thing only when its extremely cold out
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  7. #7 Re: High Beams
    Jan 2013
    Kansas
    You know i noticed that too on mine It only happened when it was cold, if it was a bit warmer it didnt do it
  8. #8 Re: High Beams
    Nov 2013
    Des Moines, IA
    once my heater has been on for 15minutes or so it does not happen anymore
    2007GPGTSC
    " sad thing is "
  9. #9 Re: High Beams
    Jan 2013
    Kansas
    ya, but that still shouldnt happen....
  10. #10 Re: High Beams
    Nov 2013
    Des Moines, IA
    Here is the link for an 07 GP - I see you have an 08 part should still be the same
    http://www.rockauto.com/catalog/x,carcode,1433703,parttype,4832
    PN's -15237469, 25804854
    2007GPGTSC
    " sad thing is "
  11. #11 Re: High Beams
    Nov 2013
    Des Moines, IA
    yeah I think the multi function switch is only like 60ish from rock auto.... I am going to pick up a new one here soon
    2007GPGTSC
    " sad thing is "
  12. #12 Re: High Beams
    the 04+ should be very similar.
    taking the steering wheel off will help you to see whats holding it all together. you dont have to take it off, but i found it helped when i did mine.
  13. #13 Re: High Beams
    Jan 2013
    Kansas
    Just a question and would like your guys suggetion, should i just swap it out with the one i have or should i swap it for one with the fog light control as well. cuz my car just has the signal light in the bottom but i would like to get some lights that are half signal and half fog. Or would that be to big of a hassle?
  14. #14 Re: High Beams
    Jan 2013
    Kansas
    Well i dont want to take off more then i have to for fear of messing something up, plus my steering wheel has all the radio controls so i bet there are a bunch more wires..
  15. #15 Re: High Beams
    Nov 2013
    Des Moines, IA
    I wouldn't mess with it ... put in a pair of LED switchbacks assuming your DRL's are the voltage varying low beams .. throw on a pair of LED switchbacks w/ resistors and call it a day. wont emit all that much light but they will be pretty bright
    2007GPGTSC
    " sad thing is "
  1. Headlights have little change from high to low beams?
    By teejay in forum General Tech Discussion
    Last Post: 02-11-2013, 05:56 PM
  2. high beams.
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 01-14-2012, 03:44 PM
  3. fog lights with high beams?
    By RyanL in forum Visual/Body Modifications
    Last Post: 09-20-2011, 10:05 PM
  4. Fog lights on with high beams.
    By BackInBlack in forum How To Write-Ups/Tech Tips
    Last Post: 08-15-2010, 05:30 PM
  5. No High Beams
    By taximech in forum General Tech Discussion
    Last Post: 06-23-2009, 11:37 AM
