Alright currently running two 12" 4 ohms DVC RF 500WRMS in parallel at 1 ohm with a 1000WRMS Hifonics amp. I am currently running 4ga wire back, and grounding out the amp to a clean strut post. I currently have some dimming of the lights at higher sound levels. I have upgraded all in the big 3 minus battery negative to block with 0 gauge wire. I am looking at going with 2 12" 4 ohm DVC 1000WRMS subs and a 2000WRMS Hifonics Brutus wired in parallel to 1 ohm.. I am planning on upgrading the battery negative to 0 gauge, along with power wire going back, and amp grounding wire. Obviously I probably won't be able to provide the Brutus with 14.4V.... but is there anything I should do to help get closer to that? Outside of adding a cap or bigger alternator.
