Thread: Correct wiring harness??
Results 1 to 6 of 6
  1. #1 Correct wiring harness??
    Aug 2013
    Parkersburg WV
    cant tell which wiring harness to use my car has 8 speakers but doesnt look like bose.....is there a way to tell from the vin#?
  2. #2 Re: Correct wiring harness??
    Aug 2013
    Parkersburg WV
    anyone???Help???
  3. #3 Re: Correct wiring harness??
    GTP Level Member simbah's Avatar
    Lala land
    Make, model and year of car would be helpful.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  4. #4 Re: Correct wiring harness??
    Aug 2013
    Parkersburg WV
    97 gtx,8 speakrs
  5. #5 Re: Correct wiring harness??
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    No Bose in 97, still has a small Delco amp near glove box. Not sure how the wire harness differs from the standard to the eight speaker set ups
    Sent from my VS920 4G using Tapatalk
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  6. #6 Re: Correct wiring harness??
    There is no harness adapter for the non bose 8 speaker system, you need to find what wire in the harness turns the amp on and hook the power turn on lead to it. Or just bypass the amp.
    Just buy the normal harness adapter for the 88-05 or whatever GM. This one http://www.walmart.com/ip/Scosche-Ge...r-GMDA/1863068 Even with that adapter you will not get sound out of your 6x9s unless you find a way to turn on the amp or bypass it.
  1. Wiring Harness
    By Dr Cedric in forum Visual/Body Modifications
    Last Post: 08-17-2014, 12:17 PM
  2. 06 Wiring Harness HELP!?
    By Springer09 in forum Audio, Security & Visual Electronics
    Last Post: 09-23-2012, 09:11 PM
  3. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  4. zzp wiring harness
    By TheOtherNick in forum Audio, Security & Visual Electronics
    Last Post: 11-03-2008, 02:47 PM
  5. 04+ Wiring harness
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-27-2008, 03:22 PM
