Quote Originally Posted by Grandprix202 View Post
What ground did you have to look at... Where is it at?
I just tapped into the wiring at the stock light. I had an issue with the wiring at the trunk release on the lid; I could wiggle the plug and make the trunk light go on/off/dim. I snugged up the terminals in the plug (fixing the bad ground), and it has worked fine for over two years.
My LED Trunk Light Install
