Thread: What is the best option for aftermarket fog lights?
Results 1 to 16 of 16
  1. #1 What is the best option for aftermarket fog lights?
    SE Level Member void33's Avatar
    Jan 2013
    Chicago
    I have a 2000 Grand Prix GT and I just bought some retrofitted projector headlights, love them. However they are 6000k and my stock fog lights are more like 4300, looks terrible. I see Diode Dynamics has some LED's for sale for the fog lights, but they also say that even the $60 (Stage 2) lights that they sell are not as bright as the stock lights.
    What are my options for upgrading? Is there any bulb I can just pop in and get a bright white fog light without doing a retro fit or HID conversion? If not, what does it take to do an HID conversion?
  2. #2 Re: What is the best option for aftermarket fog lights?
    antioch ill
    Led are just for show not function. And if you wanna run hids you will need glass fogs otherwise you will melt them
  3. #3 Re: What is the best option for aftermarket fog lights?
    Jan 2013
    Chicago
    Okay I will stay away from the led's then. The main reason I got the projectors is because I do a lot of backpacking and camping and driving down dark forest roads in the middle of the night can be dangerous. Sometimes it is foggy, I will absolutely need some functional fog lights.
    Does anyone sell a complete fog light kit for HID's? I did a little searching but couldn't find anything and I also couldn't find a How-To anywhere.
  4. #4 Re: What is the best option for aftermarket fog lights?
    antioch ill
    Nope. Get pilot housings make a bracket to fit. Then get h3c bulbs and 35w ballasts
  5. #5 Re: What is the best option for aftermarket fog lights?
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    I have these, and so do 2 of my friends no melted housing
    Xeno HID Kit H1 H3 H6M H4 H7 H8 H11 H9 H10 H13 9004 9005 9006 9007 D2S D2R 6000K | eBay
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  6. #6 Re: What is the best option for aftermarket fog lights?
    Jan 2013
    Chicago
    How do they work? Are they nice and bright and white? Also, did you need a harness?
  7. #7 Re: What is the best option for aftermarket fog lights?
    May 2011
    Tampa FL near USF
    I love them, there are plenty of colors, so you can match your 6k lights, I relied on my fog lights when i had halo/ projectors cause the light output was terrible. and everything comes with the kit, there is a wire that plugs into the factory plug, that plugs into the ballast, then u plug the bulbs into the ballast.
    I do recommend you mount the ballast under the headlights not on the bumper near the fog light housing, cause mine fell off and i had to replace one
  8. #8 Re: What is the best option for aftermarket fog lights?
    May 2011
    Tampa FL near USF
    also there are these,
    Hella “Angel Eyes” Driving Lights: 3800 Performance
    they have always looked cool to me, but never wanted to spend the money
  9. #9 Re: What is the best option for aftermarket fog lights?
    Jan 2013
    Chicago
    I think I will go with the Ebay set, do you know which model bulb to get?
  10. #10 Re: What is the best option for aftermarket fog lights?
    May 2011
    Tampa FL near USF
    Quote Originally Posted by void33 View Post
    you will need an 880 bulb
  11. #11 Re: What is the best option for aftermarket fog lights?
    antioch ill
    Dont go with a ebay set unless you plan on replacing tem every six months
  12. #12 Re: What is the best option for aftermarket fog lights?
    Jan 2013
    Chicago
    Oh really? Is there an alternative that is similar to that set on Ebay though?
  13. #13 Re: What is the best option for aftermarket fog lights?
    antioch ill
    are you talking about the actual housings or hids. if you are talking about hids there is no good ebay kits go with ddm tuning vvme or theretrofitsource.com
  14. #14 Re: What is the best option for aftermarket fog lights?
    Jan 2013
    Chicago
    So I could get this: DDM Tuning 35W and 55W HID Kits
    35Watt
    880/862/881/893/898/899 etc
    6000k
    +Mounting Bracket
    + Dual in/Dual out Harness
    +H1/H7 to 9006 Adaptor Cable
    Is that correct?
  15. #15 Re: What is the best option for aftermarket fog lights?
    Pennsylvania, USA
    If you use those HID's in anything but projectors, they're going to be horrible when used in actual fog. The beams are going to go everywhere, and you want fog lights to just light downwards so they don't illuminate the fog itself. Retrofit your fogs or get brighter halogens.
  16. #16 Re: What is the best option for aftermarket fog lights?
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. We're door lights an option ?
    By JT2002GTP in forum General Grand Prix Discussion
    Last Post: 06-13-2013, 10:15 AM
  2. GP Aftermarket Tail Lights
    By MattF in forum General Grand Prix Discussion
    Last Post: 01-22-2013, 08:06 PM
  3. New GM head lights or AMS aftermarket?
    By Skillet in forum General Tech Discussion
    Last Post: 01-12-2012, 09:47 PM
  4. Aftermarket tail lights?
    By NaturallySmashed in forum Visual/Body Modifications
    Last Post: 04-09-2009, 09:29 AM
  5. aftermarket tail lights
    By gtpinsc in forum Visual/Body Modifications
    Last Post: 08-05-2008, 05:17 AM
