If you are not going to use the Monsoon amp the the GMOS-01 is the harness you would want to use, unless you don't want the chimes then the Metra harness should work for you, but remember without chimes it might be easier to lock keys in car or leave headlights on and drain battery or even run out of gas, as all of these have chimes to remind you of these things.
