Thread: Bose amp died help plz..specs on amp?
Results 1 to 7 of 7
Solid Steel Bose amp died help plz..specs... 07-29-2013, 04:54 PM
Bills1997GTP Re: Bose amp died help... 07-29-2013, 05:32 PM
Solid Steel Re: Bose amp died help... 08-01-2013, 09:49 PM
Bills1997GTP Re: Bose amp died help... 08-02-2013, 11:19 AM
BillBoost37 Re: Bose amp died help... 08-02-2013, 11:38 AM
The Guz Re: Bose amp died help... 08-02-2013, 01:23 PM
Kilroy Re: Bose amp died help... 08-02-2013, 08:12 PM
  1. #1 Bose amp died help plz..specs on amp?
    Apr 2012
    Sudbury
    My Bose amp is dying. When I turn my aftermarket deck up or even just let it sit for 2 mins it shuts down and the speakers shut off. Looking for the specs such as RMS it shoots out so that I can just buy an aftermarket amp to power my speakers. and is there caps between the tweets or does the bose amp do all that?
  2. #2 Re: Bose amp died help plz..specs on amp?
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Bose amp? as in the factory amp?
  3. #3 Re: Bose amp died help plz..specs on amp?
    Apr 2012
    Sudbury
    Quote Originally Posted by Bills1997GTP View Post
    yes its factory the black one in the trunk
  4. #4 Re: Bose amp died help plz..specs on amp?
    Oct 2012
    Philadelphia
    Have you checked the fuse in the glovebox for the amp? And also if there's a ground line that goes to the amp check that
  5. #5 Re: Bose amp died help plz..specs on amp?
    If you figured the amp was bad and wanted an easy replacement.. hit a JY.. there's billions of those amps selling cheap.
  6. #6 Re: Bose amp died help plz..specs on amp?
    Dec 2008
    Lawndale, CA
    I don't know the specs on the factory speakers but you could just get another bose amp. Or you could upgrade to an aftermarket amp and upgrade the speakers as well.
  7. #7 Re: Bose amp died help plz..specs on amp?
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    I agree. Either just ge another Bose amp from the wreckers, or update your entire sound system. Two easiest options. Trying to work in an aftermarket amp tot he stock Bose system will be a nightmare.
  1. Gtp has died twice
    By bowtie44s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2013, 08:36 AM
  2. my maf died
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2011, 12:39 AM
  3. Does Bose Work with Non-Bose cars?
    By grandprix17 in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2010, 08:07 AM
  4. My car died
    By GPGTkid01 in forum General Tech Discussion
    Last Post: 10-20-2009, 08:25 PM
  5. So..... The gtp has died... =[
    Last Post: 08-08-2009, 02:55 PM
