Thread: one headlight not working
Results 1 to 3 of 3
3100sfi one headlight not working 07-18-2013, 04:59 PM
BillBoost37 Re: one headlight not working 07-19-2013, 06:25 AM
3100sfi Re: one headlight not working 07-19-2013, 04:21 PM
  1. #1 one headlight not working
    SE Level Member 3100sfi's Avatar
    Jul 2011
    Canada
    I have friend with a later model (2007) Pontiac Grand Prix. Got a passenger side headlight out and he replaced the bulb to no avail...it was back together before I got to look at it so I didn't check voltage at the plug but he tried several bulbs and none worked so it's fairly safe to assume voltage is not present at the connector, but I'll check anyway.
    I did check the fuse, and it was not blown. Didn't have my meter or test light so I couldn't really diagnose anything.
    A few months ago I replaced the HDM relay when both low beams were out.
    I just want to know if this is a common problem with Grand Prix of that era? I know it was always a problem with Cavaliers, Sunfires etc where wires would chafe behind the washer tank. Just curious if this happens often.
    1996 Pontiac Grand Prix SE coupe - white - stock until something breaks
  2. #2 Re: one headlight not working
    Not common. I'd check for ground as well as power.
  3. #3 Re: one headlight not working
    Jul 2011
    Canada
    Thanks, just good to know it's not a pattern failure.
    Other lights in the housing share the same ground, and they work, so the ground is present. All the same, I checked it and it's a good ground.
    No power to plug for the bulb, no power to that wire for the headlight housing (harness runs to the headlight housing where power is split to all of the bulbs), followed it back to the fuse box and found no power coming from there. Fuse is good and hot on both sides.
    I'm suspecting the connection is bad inside the fuse box.
  1. My headlight retro will beat up your headlight retro
    By 2003 SSEi in forum Visual/Body Modifications
    Last Post: 05-16-2013, 02:49 PM
  2. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
  3. Two Morimoto projectors one cup...uh...I mean headlight...headlight
    By RedDawnGXP in forum Visual/Body Modifications
    Last Post: 03-23-2011, 05:07 PM
  4. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
