Thread: HID kit wont work please help
Results 1 to 6 of 6
Project98GT HID kit wont work please help 07-13-2013, 01:56 PM
whitegt956 Re: HID kit wont work please... 07-13-2013, 02:01 PM
Project98GT Re: HID kit wont work please... 07-13-2013, 05:19 PM
whitegt956 Re: HID kit wont work please... 07-13-2013, 05:21 PM
Jake U Re: HID kit wont work please... 07-13-2013, 05:22 PM
Project98GT Re: HID kit wont work please... 07-14-2013, 10:02 AM
  1. #1 HID kit wont work please help
    Apr 2012
    Detroit Lakes, Mn
    Ok I bought a hid off ebay and I installed it last night. When I start the car and turn on the headlights they dont turn on. I wired in both grounds and the positive to the wire that goes to the fuel box under the hood. I took a power probe 3 to make sure I was getting good grounds and they are good. I pulled the fues for the DRL as i found out they can be a problem for HID's. What I found to be a bit strange is that the kit only plugs into one headlight harness and not both. but I seen some youtube videos with that same set up and they work just fine. Oh I also tryed some different ballasts too and still nothing. I have no idea what the problem is. From what I know the ground wire on the 9007 set up is in the center and the high beam is on the right of it with looking at it with the flat part down so the low beam would be to the right. Well any info on what im doing wrong or anything to get the hid's working in my car would be great. I have a 1998 GP GT if you didnt already figger it out. Thanks
  2. #2 Re: HID kit wont work please help
    SE Level Member whitegt956's Avatar
    Jul 2013
    edinburg,texas
    Are you sure your headlight breaker hasn't shut off, also have you tried regular lights just to make sure currents passing?
    Sent from my Amazon Kindle Fire HD using Tapatalk 4 Beta
  3. #3 Re: HID kit wont work please help
    Apr 2012
    Detroit Lakes, Mn
    By headlight breaker do you mean headlight switch? Because I turn them on with the switch insted of letting them come on with the auto senser. And once I found out that they wern working I changed it back to th regular bulbs so I can drive my car at night and yes they work just fine that way. Its just the hid kit isnt working. And have no idea why.
  4. #4 Re: HID kit wont work please help
    Jul 2013
    edinburg,texas
    Sometimes the input needs to be flipped on ballast, try that.....
    [hide]you sneaky rat, abducted from Amazon's ex, CM10.1 kindle, by Tapatalk 4[/hide]
  5. #5 Re: HID kit wont work please help
    SE Level Member Jake U's Avatar
    Apr 2013
    Waukesha, WI
    Try to flip the wires. I know when i put my HIDs into my projectors the positive and negative wires looked like they were switched from the stock light plug.
  6. #6 Re: HID kit wont work please help
    Apr 2012
    Detroit Lakes, Mn
    I got them to work. It was a plug that runs to both ballasts. Thanks for all the help guys
  1. Headlights WONT WORK
    By daltman360 in forum General Tech Discussion
    Last Post: 04-03-2013, 07:00 PM
  2. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  3. My windows wont work.... HELP is appreciated
    By nickskip08 in forum Introductions/Noob Questions
    Last Post: 01-16-2013, 11:30 PM
  4. a/c wont work and heat wont go to floor PLEASE HELP!!
    By Brett Muszynski in forum Introductions/Noob Questions
    Last Post: 02-10-2012, 05:43 AM
  5. ddm hid fogs wont work
    By gpgt04 in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2010, 12:37 PM
