Thread: Where to splice in remote wire?
Results 1 to 16 of 16
  1. #1 Where to splice in remote wire?
    Mar 2013
    High Point, NC
    So, I got my amp hooked up to my subs, powered, grounded, and I don't know where to splice in my remote wire. I have a 2004 Grand Prix GT, and the remote wire is run down the passenger side. Help!
  2. #2 Re: Where to splice in remote wire?
    London Ont, Canada
    factory HU or aftermarket?
  3. #3 Re: Where to splice in remote wire?
    Info or no answers.
    I'm turning over a new leaf...no more guessing.
  4. #4 Re: Where to splice in remote wire?
    that all depends on the amp your using, does it need a signal from the radio? or just 12 volt source?
  5. #5 Re: Where to splice in remote wire?
    I always used toggle switches for my amps. I've since grown up and don't need that nonsense anymore.
  6. #6 Re: Where to splice in remote wire?
    learned how to us the correct wire Dan...lol
  7. #7 Re: Where to splice in remote wire?
    The first system I had I had no idea how to hook it up and the battery died continuously because I hooked the 12v and remote together lol
  8. #8 Re: Where to splice in remote wire?
    i added a add a fuse to the wiper fuse in the fuse box, amp on when the cars on, off when the cars off.
    most amps have a little light or 2, they mean stuff lol that way you can tell if its still got power after you turn off the car.
  9. #9 Re: Where to splice in remote wire?
    London Ont, Canada
    i hook my remote wire up to the remote wire on my deck.. it does the work
    aftermarket FTW.
  10. #10 Re: Where to splice in remote wire?
    aftermarket FTW.
    Same here..my first amp and everything works like it should..
  11. #11 Re: Where to splice in remote wire?
    London Ont, Canada
    adding a sub to stock seems dumb.. so much better aftermarket options.
  12. #12 Re: Where to splice in remote wire?
    adding just a sub to a stock radio does more then you think. makes it just loud enough for me, im not a kid anymore so i dont need to loose any more hearing or break the sun roof.........
  13. #13 Re: Where to splice in remote wire?
    I don't "like" a whole lot of stuff, but that seemed to be a shot right below the hairline .....lol
  14. #14 Re: Where to splice in remote wire?
    Ill post pictures later of where I had my remote wire hooked up on the inside fuss box.
    04 Comp G.
  15. #15 Re: Where to splice in remote wire?
    Mar 2013
    High Point, NC
    It's the factory HU, and the input is going to the amp from a Scosche Line Out Converter. The amp is a Boss Chaos Exxtreme CX250 400W 2-channel.
  16. #16 Re: Where to splice in remote wire?
    if the directions say it needs a 12 volt source hook it up to the fuse box to a ignition on only fuse, wipers works well. get a add a fuse deal so the wipers still work if the fuse blows for the amp.
  1. Alternative for remote wire?
    By jakeanator in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2013, 11:24 PM
  2. Quick Splice connectors with remote start..
    By Peacher213 in forum Audio, Security & Visual Electronics
    Last Post: 10-31-2012, 01:23 PM
  3. Amp Remote Wire
    By Xorbex in forum Audio, Security & Visual Electronics
    Last Post: 06-26-2010, 06:10 PM
  4. Need to know remote wire color
    By ljj in forum General Tech Discussion
    Last Post: 05-13-2010, 08:13 PM
  5. blue remote wire
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2009, 11:30 PM
