Thread: Easiest fix for LED signals
Results 1 to 20 of 21
  1. #1 Re: Easiest fix for LED signals
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by douger View Post
    Not that I'm doing this, but there's a right way and a wrong way to install a diode, which is an electrical one way check valve. He's gonna need to know whether the flow is towards the lamp or away. Alternatively, was the band on the diode towards the bulb or away. The band indicates the no flow direction.
    I'm guessing the band is on the voltage side.
    Sorry. I presumed knowledge of diode was known.
    The cathode (band) goes toward the bulb, on the 12v side (blue wire). You want to allow electricity to the bulb, but not feed-back to the circuit.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Easiest way to contact Tim King?
    By lafenatu in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2012, 09:06 PM
  2. Best Motor easiest swap?
    By Rolling89GPSE in forum Engine
    Last Post: 01-06-2011, 12:34 AM
  3. which way is easiest?
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 08:09 PM
  4. Easiest HP gains
    By mikes_comp_g in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:17 AM
  5. easiest shift kit to install ?
    By bayareagtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2008, 09:18 AM
