Thread: projector led halo headlights problem
Results 1 to 9 of 9
  1. #1 projector led halo headlights problem
    May 2013
    Grand Ledge Michigan
    So i bought a pair of projector headlights with halo and led light.. spliced them with my turn signal wires and it went all down hill from there..now my headlight switch dont turn on my parking lights and my dash light went out also with the door open without my car on or no key in ignition it constantly dinging.. (99 GP GT)
  2. #2 Re: projector led halo headlights problem
    SE Level Member sdogg201's Avatar
    Mar 2012
    Saginaw
    you didn't tie the halos and LED's in with the fogs? did you check fuses? Did your wire them up right? undo what you did and see if it fixes it. I would go through the fog lights not the parking lights as they are tied in with the blinkers (at least on my 98 GTP)
  3. #3 Re: projector led halo headlights problem
    Mar 2012
    Saginaw
    I will come fix the issue for gas money there and back lol
  4. #4 Re: projector led halo headlights problem
    May 2013
    lol that could be a good deal.. but ya i was checking the fuses under the hood and the it does look like a few may be bad..but i dont see how everything was working perfect before i attempted to install these friday.. now my fog lights work with my brights and not with low beams and switch has no control.. parking lights now only work with turn signals/ led and halo flash with them but dont have control over parking lights either..just low and high beams
  5. #5 Re: projector led halo headlights problem
    Mar 2012
    Saginaw
    You have them all missed wired. that is the problem for sure. undo everything and hook up our oems the way they were and see if it fixes the issue. there are fuses un the glove box as well not just under the hood. like I said I can help out if needed. also post some pics through photo bucket so I can see your wiring job and we can trouble shoot it from there.
  6. #6 Re: projector led halo headlights problem
    May 2013
  7. #7 Re: projector led halo headlights problem
    May 2013
    those are how i have it currently... my oems are currently not with me.. will able to get tommorow
  8. #8 Re: projector led halo headlights problem
    May 2013
    ok...its not pretty at all though
  9. #9 Re: projector led halo headlights problem
    Mar 2012
    Saginaw
    lol. well post what you can so I can look at it. Also try to get the wires as well where you connected at as well
  1. Halo Projector headlights
    By smitz327 in forum Shops and Community Heroes
    Last Post: 05-09-2013, 12:57 PM
  2. Led halo projector headlights
    By Mad GTP in forum Visual/Body Modifications
    Last Post: 02-20-2012, 06:19 PM
  3. Halo Projector Headlights + LEDs
    By 2000superGrandPrix in forum Visual/Body Modifications
    Last Post: 04-04-2011, 05:06 PM
  4. Custom Halo's in non-projector headlights?
    By chamilton89 in forum Visual/Body Modifications
    Last Post: 05-04-2010, 01:38 PM
