Thread: Headlight Moisture :((
Results 1 to 5 of 5
  1. #1 Headlight Moisture :((
    SE Level Member Toya439's Avatar
    May 2013
    United States
    Basically what the title says headlight have moisture in them and its annoying how can i fix it? or does someone have some replacements for cheap ?
  2. #2 Re: Headlight Moisture :((
    Nov 2011
    NY
    It's the seal around the lamp, or the plastic seal is gone. Either way, silicone is your friend...
  3. #3 Re: Headlight Moisture :((
    No, sorry the title doesn't say it all.
    Year and model is always good to mention.
  4. #4 Re: Headlight Moisture :((
    May 2013
    United States
    Oh,Sorry its a 02 GP GT Coupe
  5. #5 Re: Headlight Moisture :((
    GT Level Member Shiftingshaddow's Avatar
    KC
    you can clean the outside with toothpaste. it will help. cleaned my van right up. cleaned the outside of my gtp and made a noticeable difference. however, if the inside is fogged or hazed up you can take your light assembly out and bake them in the oven for like 10 minutes on low heat (like 200) to separate the lense from the frame. clean them up, and glue them back together and then seal them with silicone or something.
    i'm pretty sure there is a write up in the how to on how to bake them.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  1. Moisture in the head/taillights
    By Ninjo in forum General Tech Discussion
    Last Post: 10-12-2013, 09:24 AM
  2. *Pics* Resale or replace? Moisture in headlight.
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 11-26-2012, 09:23 PM
  3. Taillight Moisture solution. 00 gt 2dr
    By Autoworks in forum General Grand Prix Discussion
    Last Post: 10-01-2012, 03:40 AM
  4. Halo's Have Moisture
    By mikroehl in forum Visual/Body Modifications
    Last Post: 03-22-2009, 07:35 AM
  5. Moisture in Headlights
    By Dohner in forum Visual/Body Modifications
    Last Post: 02-19-2008, 01:39 AM
