Thread: guage install
Results 1 to 5 of 5
t wizzle17 guage install 04-25-2013, 01:16 PM
DanPrixGTP Re: guage install 04-25-2013, 01:18 PM
t wizzle17 Re: guage install 04-26-2013, 02:27 PM
DanPrixGTP Re: guage install 04-26-2013, 02:30 PM
rperry435 Re: guage install 04-26-2013, 02:30 PM
  1. #1 guage install
    Mar 2013
    amherst
    Have. Volt guage and boost guage I'm looking to install in my 02 gtp. Just looking for a diagram or picture of were the power for the ignition switch is. Or if their is an alternative power wire to use.
  2. #2 Re: guage install
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Run both power wires across to the Fuse box in the glove box. Run the wires from your pillar, down the side of your car, under the dash, all the way to fuse box. Bring the wire in from behind.
    Hook up to switched 12v, such as the Radio fuse.
    Get an "add-a-fuse" from your local auto parts store.
  3. #3 Re: guage install
    Mar 2013
    amherst
    And were do I put the t for the clear hose ?
  4. #4 Re: guage install
    Jun 2011
    Map sensor vacuum line.
    Mine is the Bronze T.
  5. #5 Re: guage install
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Or drop the knee panel and attach it to the ignition wire off the ignition switch. :what:
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. gpo and guage pod
    By Matt Palm in forum Visual/Body Modifications
    Last Post: 09-01-2012, 06:23 PM
  2. led's guage
    Last Post: 04-11-2012, 06:52 AM
  3. no gas guage need help!
    By mikedinthecity in forum General Tech Discussion
    Last Post: 04-28-2011, 09:38 PM
  4. gas guage
    By 07gpx in forum Introductions/Noob Questions
    Last Post: 09-07-2009, 05:58 PM
