Thread: Center Console Lights
Results 1 to 4 of 4
MattF Center Console Lights 04-05-2013, 01:10 PM
Bluemagic Re: Center Console Lights 04-05-2013, 02:13 PM
Matt Palm Re: Center Console Lights 04-05-2013, 02:15 PM
LS1GTP Re: Center Console Lights 04-05-2013, 02:20 PM
  1. #1 Center Console Lights
    Sep 2012
    Cedar Rapids, Iowa
    Has anyone swapped out the lights near the center console where it says P, N, D, R, etc. and could give me a basic idea of how to get at those lights to swap them?
  2. #2 Re: Center Console Lights
    Dec 2010
    DMV
    Yup. There's a write up somewhere around here.
  3. #3 Re: Center Console Lights
    antioch ill
    pull the console off and then there is a plug with a bulb in the socket and thats it really.
  4. #4 Re: Center Console Lights
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Remove shifter knob- use flathead screwdriver to remove metal clip on the back of it and pull up. Don't yank it, you'll break the wires for the performance shift button if you have that.
    Open center console.
    Remove compartment, it lifts out.
    Pry up on the center console on each side by the compartment, flathead screwdriver.
    Once you pop that part up, there's 4 or 6 more of those that run along the center console. Just keep lifting it up while using common sense.
    Unplug the performance shift if you have it. Unplug heated seat button if equipped.
    Now you'll see that all the letters are lit by 1 bulb. Replace it with whatever you want, use LED strips, etc. Whatever you had in mind.
    Hope this helps.
  1. Center Console
    By Mcbride in forum Visual/Body Modifications
    Last Post: 01-28-2013, 05:08 PM
  2. Center console lights
    By 06 base in forum Visual/Body Modifications
    Last Post: 02-21-2010, 12:19 AM
  3. center console
    By flash527 in forum Visual/Body Modifications
    Last Post: 11-18-2009, 02:43 PM
