Thread: 04+ compass module info
Results 1 to 4 of 4
  1. #1 04+ compass module info
    Yoga city
    Just putting some info out there for ppl
    diagram:
    Connector:
    7-8 -- -- Not Used
    9 WH 193 Rear Defog On Signal
    10 -- -- Not Used
    11 BN 1779 Compass Data Signal
    12 D-BU 1778 Compass Clock Signal
    13 PK 739 Ignition 1 Voltage
    14 BK 550 Ground
    15 -- -- Not Used
    Compass calibration:
    Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
    1. Turn ON the ignition.
    2. Press the MODE button in order to advance to the COMPASS CALIBRATION mode.
    3. Press the SELECT button in order to display PRESS RESET TO RECALIBRATE.
    4. Press the RESET button.
    5. Drive the vehicle in circles at a speed of less than 10 MPH (16 km/h) until the DIC displays CALIBRATION COMPLETE and the compass displays the proper vehicle heading. The calibration procedure is now complete.
    Compass magnectic varation:
    Magnetic variation adjustments are required when the compass displays a constant error in heading. Variation is the difference between magnetic north and true north due to geographical location.
    Locate your geographic location. Refer to the variation zone map.
    Turn ON the ignition, with the engine OFF.
    Press the SELECT button in order to display RESET CHANGES ZONE.
    Press the RESET button in order to advance to the proper zone number.
    Press the MODE button in order to enter and set the zone number.
    Removal of compass module:
    Remove the rear shelf trim panel. Refer to Rear Window Shelf Trim Panel Replacement.
    1. Reposition the sound barrier for access.
    2. Disengage the electronic compass retainers.
    3. Disconnect the electrical connector.
    4. Remove the electronic compass.
    Installation:
    Connect the electrical connector.
    Align the electronic compass to the openings in the rear shelf. Install the electronic compass.
    Install the sound barrier.
    Install the rear shelf trim panel. Refer to Rear Window Shelf Trim Panel Replacement.
    Refer to Control Module References for programming and setup information.
  2. #2 Re: 04+ compass module info
    Sep 2016
    Columbus, Ohio USA
    I am not able to see those photos through Photobucket. I have not been able to locate the wiring harness for the compass in my 2007 base model. I am hoping to upgrade my system to the 5 button and already have the temp sensor. I found a small white box under my speaker panel and have not been able to locate any other wires.
  3. #3 Re: 04+ compass module info
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Don't know about the wiring, but I can help you with the photos.
    You can see the pictures in Photobucket by "right-clicking" on that lame gauge image, and then clicking "Open Image in New Tab". It will take you to the source file for that photo. This works on an actual computer, not sure about mobile.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  4. #4 Re: 04+ compass module info
    SWPA
  1. 05 GP compass module help
    By Poseidon215 in forum General Tech Discussion
    Last Post: 05-24-2011, 05:04 PM
