Thread: Driver Information Center not working 2000 gtp
Results 1 to 20 of 20
  1. #1 Driver Information Center not working 2000 gtp
    iowa
    The battery was unhooked for about a week while at the body shop. Picked it up last thursday and the buttons all light up but the main screen does nothing. He called a local dealer and he said it has to be turned on by a tech 2, which I think sounds rediculous. I checked every single fuse, I did find the hvac mini fuse inside the car was missing, but the dic/hvac was in tact and still good. Everything else in the car works perfectly as it should. I even pulled the dic out and took it appart to checka bulb and it's good. Checked all 12v on the harness going to it and there's power where there should be. Kind of lost at this point. I was thinking about going to get another dic from the junkyard but the car only has 8000 on it now. BTW the body shop did a great job repairing the car, just waiting on one more nos part.
    87 buick gn-fmic, 3200 stall, meth injection, gt35r/76ptrim at 24psi, 204/214 cam, 60lb injectors (at 95%dc)
    .....Then there's the wife's driver
  2. #2 Re: Driver Information Center not working 2000 gtp
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    I had to replace mine with one from a junk yard car. When it started to go only one side would light up until I tapped on it. Once that stopped working I had no choice. The procedure to replace the bulb just wasn't worth the trouble considering how inexpensive a replacement dic is.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  3. #3 Re: Driver Information Center not working 2000 gtp
    Jul 2010
    Detroit
    One more note, once mine finally went it still came on but you really had to strain to see it. Bulbs looked good on mine as well.
    Ryan
  4. #4 Re: Driver Information Center not working 2000 gtp
    iowa
    Is there any way to check them to see if theyre good? I'm assuming the grounds have to be grounded. After that you should be able to put 12v to each pin right?
  5. #5 Re: Driver Information Center not working 2000 gtp
    gardner,mass
    i sell these bulbs at CAP for like 80 cents
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  6. #6 Re: Driver Information Center not working 2000 gtp
    iowa
    It's not the bulbs. Pretty sure it's burned up from the door getting f'ed up. I remember when I moved the car off the street the dome light wasn't on and the door was obviously open. I'm thinking it got fried.
  7. #7 Re: Driver Information Center not working 2000 gtp
    gardner,mass
    i got a new one from my local jy for my old 2000 for 15 bucks
    actually i have it sitting in my closet right now
    post a pic of yours cus some are different
  8. #8 Re: Driver Information Center not working 2000 gtp
    iowa
    Quote Originally Posted by Coleslaw View Post
    It would be easier for you to post a pic of the one you have. Cell phone pics are too sophisticated for this website.
  9. #9 Re: Driver Information Center not working 2000 gtp
    iowa
    I'm sure it's the same one, car is the same year, as long as it's from a gtp it should work.
  10. #10 Re: Driver Information Center not working 2000 gtp
    gardner,mass
    Quote Originally Posted by usetaboost View Post
    well see back then i just grabbed it for the bulbs and it was a little different from my gtps, but ill post a pic for you tonight and if you want it you can have it if you send me a return label and ****.
  11. #11 Re: Driver Information Center not working 2000 gtp
    iowa
    ok I'll check back later
  12. #12 Re: Driver Information Center not working 2000 gtp
    gardner,mass
    this is what the one i have looks like
    1997 97 Pontiac Grand Prix GT Driver Information Center Dic GT 97 Only | eBay
    but for some reason im missing the plastic trac button but you could probly just use the one out of yours and there are no bulbs in it but you can use your old ones or buy some new ones
    just pm me if your interested and i can give you my address to send me a return lable and ill send it to ya
  13. #13 Re: Driver Information Center not working 2000 gtp
    Jul 2010
    Detroit
    I read somewhere that A 97' DIC won't work in a 00' GTP. 97's were the only year to have tire pressure monitoring.
    Ryan
  14. #14 Re: Driver Information Center not working 2000 gtp
    gardner,mass
    it turned on when i plugged it in to try it in mine but i didnt really test it
  15. #15 Re: Driver Information Center not working 2000 gtp
    iowa
    THinking about figuring out a way to bench test mine. I've had a place in town that specializes in automotive electronics look at it and they agree with me that the screen is burned out but I'd like to verify it for sure.
  16. #16 Re: Driver Information Center not working 2000 gtp
    iowa
    Still looking for one. Got a few more places to check locally. Found one today that was unverified from a 99gtp, plugged it in and it didn't work.
  17. #17 Re: Driver Information Center not working 2000 gtp
    Feb 2010
    TN
    You try PartsLady? I know she has a couple
  18. #18 Re: Driver Information Center not working 2000 gtp
    iowa
    If I don't find one by the end of this week I plan on getting one from her. She pm'ed me last week and said she had one.
  19. #19 Re: Driver Information Center not working 2000 gtp
    iowa
    FIgured I'd follow up on this. ENded up being a fried dic. I got a NOS one for the car and it worked just fine.
  20. #20 Re: Driver Information Center not working 2000 gtp
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    For future reference, if your DIC goes blank, shine a bright flashlight on it while your car is on. If it is just the bulbs, you will still see information changing after you shined your flashlight into it. If you see no changes, then the DIC is more than likely toast.
  1. Dim Driver Information Center
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 02-13-2012, 09:25 PM
  2. Driver information center (DIC) on 04 not working
    By coachbobby in forum General Tech Discussion
    Last Post: 01-11-2012, 10:13 AM
  3. Driver information center not working
    By jerrysf in forum General Tech Discussion
    Last Post: 12-06-2010, 01:09 PM
  4. Driver information center
    By sbrutcher in forum Introductions/Noob Questions
    Last Post: 02-13-2010, 03:20 PM
  5. driver information center
    By Green Machine in forum General Tech Discussion
    Last Post: 08-05-2008, 12:14 AM
