barnettimpala
Reason you probably haven't found it is because metal is a ground source. Period. The entire metal of the car is a ground. There are several grounding spots stock, so obviously it's not bad to ground to different places. The more the better the way I see it. There's no real theory you need to learn other than metal is the ground. And being that these are unibody, you dont need to worry about trying to ground to the chassis. Did you know that electricity flow starts at the ground and not the power haha
