i like what your saying, ive got 11 volts. maybe its the ground.
Originally Posted by Bronco Boy
Why would you want your trunk light to come on with your subs?
JTeske88, the BCM controls the trunk light, so I would wager that you have a bad BCM, a bad wire, or a bad ground.
You could also check the harness at the trunk latch, on the lid. I had intermittent issues that turned out to be up there; one of the pins in the connector was loose, and wiggling the harness made the light come on. After squeezing the pins so they fit tighter, it hasn't failed me.
