not sure if your radio will support the controls, but you will also need a new clock spring,(also works the airbag) as its how the wires get up the column and the wheel. then theres a short harness from the clock spring to the switches. and the steering wheel. then there's another wire that clips to the clock spring wires mounted at the lower dash, foot area, that goes off to the radio harness plug.
