Thread: Help with aftermarket headunit instead of monsoon
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Help with aftermarket headunit instead of monsoon
    gardner,mass
    So i got a jenson headunit not to long ago for basicly free and now i just got my hand on a nice sub and amp and everything needed. Now i do have a decent backround with hooking car audio up but im having trouble with this headunit. Now i got a basic wiring harness from best buy with the speakers power acc ground ect. thinking it would work, idk see why it wouldnt i just know i wouldnt have the heads up display show things and the steering wheel controls and chimes wont work, and im fine with that. I wasnt going to spend 110$ on a wiring harness for those. So my question is, have people hooked up there system with this basic wiring harness? I got it all hooked up and the unit turns on but does nothing and plays nothing so is it my headunit thats bad or the wiring harness? 2004 grand pric comp g with monsoon
    also another thing to note it came with a red ignition switch wire but had one on the harness already aswell, i hooked the one on harness to the one on the headunit. Do i need to splice in this other one and go to thefuse or power?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Help with aftermarket headunit instead of monsoon
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    the factory amp needs power
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    oic so the monsoon system has an amp that i wire that red wire from to the acc wire on deck or to a fuse box?
    or is it like a remote?
  4. #4 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    like a remote im unfamiler with the 04 but there should be a separt plug for the amp
  5. #5 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    in the wiring harness there is an amp turn on i thought this was for a sub amp but where should i splice it to? the acc wire or the fuse boxxx
  6. #6 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    on the plug that comes from the car there is a pink wire correct
  7. #7 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    i was reading a forum just now and i think 97-01 or w/e was pink and mine is tan ima go check
  8. #8 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    mine was tan your might be pink
  9. #9 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    no pink, just a tan and i tried hooking that blue amp on wire from the harness to the acc wire and it did nothing. But one thing my deck is turning on but i cannot change any setting or anything. so is my deck bad?
  10. #10 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    most likely i would try getting that amp to turn on though
  11. #11 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    ill go over my wiring i have setup.
    Headunit---wiring harness
    ground-----ground
    red ign-----red ign
    yellow bat--yel bat
    orange dim- orange dim
    and obv all speakers green,purp,white, gray
    things that arnt hooked up on harness are
    Blue amp on
    orange illum
  12. #12 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    is there another plug that goes into the factory headunit
  13. #13 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    Quote Originally Posted by Erik Adam Rodriguez View Post
    even with that amp not on though there just wouldnt be sound but the headunit would work
  14. #14 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    yes
    let me take pictures
  15. #15 Re: Help with aftermarket headunit instead of monsoon
    GTP Level Member simbah's Avatar
    Lala land
    the blue amp turn on in the harness goes to the blue amp turn on in the radio harness, this should turn on the Monsoon amp so you will get sound, just make sure you use the blue remote wire from the radio and not the one for the power antenna, which most likely is blue/white. You may have to run the red ignition wire to the fuse box and wire to an ignition powered source. The 04+ GP radio actually turn on via the data feed on the radio.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  16. #16 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    Quote Originally Posted by simbah View Post
    i do not have a blue amp turn on wire on my deck
  17. #17 Re: Help with aftermarket headunit instead of monsoon
    Lala land
    WHAT?...... Then wire the blue wire from the harness to an ignition source power to turn on the amp.
    What headunit do you have and how old is it?
  18. #18 Re: Help with aftermarket headunit instead of monsoon
    Sep 2012
    bridgeport,NY
    picture?
  19. #19 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    aftermarket wiring harness
    car wiring harness
    second plug for stock radio
  20. #20 Re: Help with aftermarket headunit instead of monsoon
    gardner,mass
    tried that to the red acc wire
  1. 04+ Gp with monsoon and onstar double din headunit swap
    By painthorsemoe in forum Audio, Security & Visual Electronics
    Last Post: 01-31-2013, 04:56 PM
  2. aftermarket headunit in 06 gxp
    By nicks98gtp in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2011, 01:45 AM
  3. Installing headunit in 04 GT2 with Monsoon
    By nickleahy23 in forum Audio, Security & Visual Electronics
    Last Post: 08-30-2011, 05:07 PM
  4. Best Aftermarket Headunit?
    By ajc549FF in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2011, 01:01 AM
  5. 2004 monsoon + aftermarket headunit
    By blabo219 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2010, 03:10 PM
