Thread: 04+ Gp with monsoon and onstar double din headunit swap
Results 1 to 17 of 17
  1. #1 04+ Gp with monsoon and onstar double din headunit swap
    Jan 2012
    Fairbanks, Indiana, United States
    has anyone done this i see most people have went to the single dins but i want the double. id really like to have the nav and all that becasue i plan on traveling over the summer. if anyone has tell me what you used. and if you can post up some pics
    sent from glade air wick spray
    I live here. DirtDog's Avatar
    Jun 2012
    Are u wanting to swap to the double din navigation one that GM made or one u buy from best buy or something?
    Sent from my DROID RAZR using Tapatalk 2
  3. #3 Re: 04+ Gp with monsoon and onstar double din headunit swap
    Jan 2012
    [QUOTE=marines542;965504]Are u wanting to swap to the double din navigation one that GM made or one u buy from best buy
    Yes one from best buy. I figure the one from gm will be alot more that and idk what to look for. What are your suggestions?
  4. #4 Re: 04+ Gp with monsoon and onstar double din headunit swap
    Yoga city
    i may be selling one come tax time, i didnt want double din, but thinking custom carputer now.
  5. #5 Re: 04+ Gp with monsoon and onstar double din headunit swap
    Jan 2012
    Quote Originally Posted by JTeske88 View Post
    How much and what are the details on it.
    Jun 2012
    If u got one with navigation from best buy or somewhere it should come with everything for the navigation to work correctly. As for the factory chimes and sounds you will have to buy a wiring harness for that. If u got a GM navigation system it would cost more and you would have to buy a antenna and wire it in the roof or dash or where ever it goes
    I don't have navi ATM but there's a add on available for it I might get down the road.
    04 Comp G.
  8. #8 Re: 04+ Gp with monsoon and onstar double din headunit swap
    Jan 2012
    Just a random question. Where's your handle for the shifter? Lol
    Jun 2012
    Where did ya get the 04+ pillar gauge...or was it a custom made one
    Custom..fiberglass FTW!
    04 Comp G.
  11. #11 Re: 04+ Gp with monsoon and onstar double din headunit swap
    GTP Level Member joshv's Avatar
    canada
    best pic i got, you will need at least 2 extra parts, u need to buy a dash kit like 20 bucks and an adapter to have ur door chimes and everything work i think the part is gmos-01 another 30 bucks. all easy to install.
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
    Jun 2012
    He's put an after market shifter handle. U can see it in the pic
  13. #13 Re: 04+ Gp with monsoon and onstar double din headunit swap
    Jan 2012
    Quote Originally Posted by marines542 View Post
    No There's no shifter on it. It's just the stick and white button to push down. But I do like where he put the bass knob.
  14. #14 Re: 04+ Gp with monsoon and onstar double din headunit swap
    GTP Level Member simbah's Avatar
    Lala land
    If you have the Monsoon sound system and you intend to keep the Monsoon amp then you will need the GMOS-04 adapter and it will run you anywhere from $80-$120 depending on where you purchase it.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
    This. Putting a gto shifter in it whenever I get around to it.
    04 Comp G.
  16. #16 Re: 04+ Gp with monsoon and onstar double din headunit swap
    Oct 2012
    Brampton,ON
    when you swapped the radios you lost the calendar right? Are you still able to view your mileage? I have a 2004 grand pix gt and im looking to swap, i dont mind losing the calendar but i wanna make sure i can view the kilometres
    Yea you'll lose the calendar feature...no buy deal 98% of aftermarket HU have a calendar anyways plus that's what a cellphones for. You will keep your kM/MPH.
    04 Comp G.
  1. Installing Factory Monsoon Headunit w/ XM - in base model Grand Prix?
    By extreme in forum Audio, Security & Visual Electronics
    Last Post: 12-27-2011, 06:34 AM
  2. 08 gp monsoon/onstar deck repl.
    By 08 gp lvr in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2011, 07:48 PM
  3. Installing headunit in 04 GT2 with Monsoon
    By nickleahy23 in forum Audio, Security & Visual Electronics
    Last Post: 08-30-2011, 05:07 PM
  4. adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 04-19-2010, 07:10 PM
  5. 2004 monsoon + aftermarket headunit
    By blabo219 in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2010, 03:10 PM
