Thread: Performed broken spring fix on HUD, still nothing?...
Results 1 to 15 of 15
  1. #1 Performed broken spring fix on HUD, still nothing?...
    Sep 2012
    AZ
    Hey guys, bought a 04 gtp and have never seen the hud work, however i did have that broken spring issue so i performed the repair today. Put it all back together and still nothing. The control knob lights up and the fuse it okay. Im positive everything is plugged in, is there snything else you guys can recommend checking out?
  2. #2 Re: Performed broken spring fix on HUD, still nothing?...
    Sep 2012
    AZ
    Still can't figure it out, anyone?
  3. #3 Re: Performed broken spring fix on HUD, still nothing?...
    Yoga city
    if you look from the outside of the car with it on can you see anything on the screen, or can you hear the motor. you could of possible not connected it correctly
  4. #4 Re: Performed broken spring fix on HUD, still nothing?...
    Nov 2012
    Madison
    So you cant see the display on windshield from any angle?
  5. #5 Re: Performed broken spring fix on HUD, still nothing?...
    Yoga city
    if the mirror, is off any you cant, gotta look from out side the car down into it
  6. #6 Re: Performed broken spring fix on HUD, still nothing?...
    Sep 2012
    AZ
    Thanks for the replys. I cannot see anything through the windshield or from outside looking down onto the glass. Also cannot hear a motor, though I've never heard it before.
    I should take it apart for the third time but I know I connected both connectors (one on the inside of the box, 2nd connecting to the box)
  7. #7 Re: Performed broken spring fix on HUD, still nothing?...
    Nov 2012
    Madison
    Well Hell ya say, fuses checked? well there is this http://www.grandprixforums.net/how-f...3-a-39798.html
  8. #8 Re: Performed broken spring fix on HUD, still nothing?...
    Except, if he's talking spring...he's likely an 04+
    Ohio
    Quote Originally Posted by rizer View Post
    ... bought a 04 gtp......
    Ahem, bill
    I live here. DirtDog's Avatar
    Jun 2012
    Did u hook the wire under the dash back up to the HUD
    Sent from my DROID RAZR using Tapatalk 2
  11. #11 Re: Performed broken spring fix on HUD, still nothing?...
    Sep 2012
    AZ
    Lol yeah it's a 04. Guess I'm gonna tear it apart again and check for power. Before I do that, is it safe cycling the key if I have the speedo unplugged? Just wanna check for voltage to the connector going into the HUD.
  12. #12 Re: Performed broken spring fix on HUD, still nothing?...
    Jun 2012
    i did on mine. i turned it on to see if the hud powered up before i put everything back together...i didnt have a problem
  13. #13 Re: Performed broken spring fix on HUD, still nothing?...
    Yoga city
    same here, just make sure your dmm probes aint crossed or anything.
  14. #14 Re: Performed broken spring fix on HUD, still nothing?...
    Sep 2012
    AZ
    Welp, took it all apart and I have 12v at the connector going into the HUD. Gutted the internals and the little white box that has all the LED's even has voltage getting to it.
    Think I'm gonna just throw it back in the car and let it be. Besides replacing the entire HUD, anyone else have any experience with this issue? I figure it has to be one of the circuit boards or something
  15. #15 Re: Performed broken spring fix on HUD, still nothing?...
    Pennsylvania
    Honestly, I had to take mine apart to do the same repair job (2004 GTP), so I went through the same thing. Mine worked when I put it back together, but while the HUD is a pretty cool little toy, it really isnt that big of a deal. It just shows the speed along with the thermometer and compass, stuff that's already on your DIC and cluster.
    If you cant figure it out getting yours fixed, just wait a little while... sometimes they come up for sale for cheap, you're not missing out on a lot while you wait, lol.
    Sport Edition Kv5 18x8
  1. Fixed broken valve spring, Still misfiring heads are off
    By Kasey in forum General Tech Discussion
    Last Post: 09-19-2011, 08:06 AM
  2. Cylinder 5 misfire UPDATE Broken valve spring
    Last Post: 09-12-2011, 07:32 PM
  3. Bent pushrod and broken valve spring?
    By brokenmercy in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-07-2011, 05:31 PM
  4. Loose Ignition Key, Broken Spring?
    By Stormwolf in forum Engine
    Last Post: 10-25-2010, 06:29 PM
  5. Broken Spring
    By pski920 in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2009, 10:53 PM
