Thread: Aeroforce wirig
Results 1 to 15 of 15
  1. #1 Aeroforce wirig
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    What wire did you guys tap into to make the aeroforce gauge start up and shut down when the car turns on or off? I have a 04 grand prix
  2. #2 Re: Aeroforce wirig
    Used a add a circut to the radio fuse. Ran the power wire from the aeroforce to there, then plug the obd 2 port in.
  3. #3 Re: Aeroforce wirig
    Oct 2011
    huntley
    My radio sucks to get in and out so is there any other way to do it?
  4. #4 Re: Aeroforce wirig
    Quote Originally Posted by hockeybawler View Post
    open your fuse box, thats where you ad the add a fuse.
  5. #5 Re: Aeroforce wirig
    You don't take the radio out. Inside the car is a fuse box for almost everything on the inside (atleast on 97-03 cars, its in the glovebox), find that fuse box and pull the radio fuse, then use the add a circut there or use the ignition fuse so it comes on when the car does.
  6. #6 Re: Aeroforce wirig
    one of these things
  7. #7 Re: Aeroforce wirig
    Oct 2011
    huntley
    Alright so on the 04+ cars the only fuse box inside the cabin that I know of is the one next to the passanger door to the right of the glove compartment. Would this be it? And do I need to use a add a fuse or could I just shove the wire in where the fuse goes and then shove the fuse back in?
  8. #8 Re: Aeroforce wirig
    Don't jerry rig it, you don't want the car to burn down.
    Buy the add a circut.
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Protect what you bought and at least have a fuse some where in the power wire.
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  10. #10 Re: Aeroforce wirig
    Oct 2011
    huntley
    Alright, I will go out and buy one tomorrow. Thanks for the help! Orielys or autozone should have one right? If not where is the best place to get one?
  11. #11 Re: Aeroforce wirig
    I'd assume they would have one, if not maybe a hardware store?
  12. #12 Re: Aeroforce wirig
    Oct 2011
    huntley
    Alright thanks for the help!
  13. #13 Re: Aeroforce wirig
    any 1/2 decent parts store will have them. ask if you dont see it.
  14. #14 Re: Aeroforce wirig
    Since you guys already fixed the issue.
    I'd like to mention that Regals.. they don't need to add the fuse for power. Aeroforce works mint right outta the box.
  15. #15 Re: Aeroforce wirig
    Jul 2010
    Coquitlam,BC,Canada
    Wrong year, but fuse tap to the radio circuit.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Aeroforce
    By tayl5645 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:39 AM
  2. aeroforce
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 02-04-2009, 08:30 PM
