Thread: fix for radio volume
Results 1 to 9 of 9
  1. #1 Re: fix for radio volume
    GT Level Member BackInBlack's Avatar
    Vermont
    These Delco radios use a 5-pin digital rotary encoder. There is a tiny bearing ball on a track that touches contacts together when you turn the knob. Eventually, the ball will flat-spot and not move properly. The encoder is made by the Alps Electronics corp., and they will NOT sell you a new one. (I've spent a LOT of time in the past working this one out...) I was working on a modification that changes the rotary knob into a rocker switch that you press up or down to change the volume, but never finished it. The switch was tied internally to the steering wheel interface for easy wiring.
    You can also turn your worn-out encoder while pulling out gently on the knob - that seems to make them work better for a while.
    I just use the steering wheel controls...
    The GPs are long gone...
  2. #2 Re: fix for radio volume
    chi-town
    i figured it would be easier to try to change the knob than wire my car for steering wheel controls
  3. #3 Re: fix for radio volume
    Canada
    I just fix these volume knob issues by lightly spraying some electronic contact cleaner in the volume knob hole and then turning the control back and forth quite a few times. This works good for about 6 months to a year --- depending on how dirty the air is that you drive your car in.
  4. #4 Re: fix for radio volume
    WI
    Fix the pics place. Thx in advance.
  1. Radio is effed up
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2010, 03:12 AM
  2. Wtf is up with this Radio?
    Last Post: 07-12-2008, 05:59 PM
