Thread: 6x9s and door speakers
Results 1 to 19 of 19
  1. #1 6x9s and door speakers
    Dec 2012
    Akron
    Plan on getting 6x9 and 5.25 door speakers was looking at these for 6x9s
    Amazon.com: polk audio 6x9
    and these for door speakers
    Amazon.com: Polk Audio DB521 5.25-Inch Coaxial Speakers (Pair, Silver): Car Electronics
    Never used Polk audio just trying to get some input and what small amp would you run wiith those not trying to spend a whole lot
  2. #2 Re: 6x9s and door speakers
    Jul 2012
    Chicago
    I've had those 6X9's. They are damn good. But personally, I like these better.. The bass is less muddy when cranked and they sparkle.
    Pioneer TS-A6994R (TSA6994R) 6" x 9" 600W 3-Way Car Speakers
    As for door speakers. Polk makes good ones. The 6.5's I had in my door lasted for 10 months before I took them out, and they were amped and thrashed daily. Still work, just decided to upgrade to components instead.
    -Carl
  3. #3 Re: 6x9s and door speakers
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    Quote Originally Posted by nos4blood70 View Post
    i bought those 6x9s on cyber monday have em installed and love them!
    as far as speaker size goes... i fit these 6.5 in my 05 door with absolutely no modding or anything..
    Pioneer TS-A1674R (TS A1674R) 6-1/2" 3-Way A-Series Car Speakers
    for the record i used this amp to power the rears and fronts
    http://www.sonicelectronix.com/item_...od-X450-4.html
    not sure why its discontinued but you can buy it here
    http://www.amazon.com/Kenwood-eXcelo...Kenwood+X450-4
  4. #4 Re: 6x9s and door speakers
    Dec 2012
    Akron
    I think ill go that route what door speakers should I go with what size doesnt require any modifying also what amp would you recommend running for the door speakers and 6x9s thank you
  5. #5 Re: 6x9s and door speakers
    Jul 2012
    Chicago
    I'm not sure if 6.5 inch speakers will fit in a Grand Prix. Unfortunately I know Bonneville's better. But anyways, this amp is what is powering my set up. I installed it myself in May. Hasn't given me any problems. Solid little thing.
    Hitron HPA400.4 (hpa4004) 400W Max, Pro Series 4-Channel
    However, if you want to keep your stock head unit you would need a Line Output converter to give the amp signal. That's how I have mine set up as well.
    -Carl
  6. #6 Re: 6x9s and door speakers
    Dec 2012
    Akron
    ok yeah the door speakers are 5 1/4 and that amp is cheap thinking ill be going that route and currently I'm running this head unit
    Sony MEX-BT4100P CD receiver at Crutchfield.com
    Last question thinking about running these
    Amazon.com: Kicker DS693 6"x9" 3-Way Speakers (Pair): Car Electronics
    and
    Amazon.com: Kicker 11ds525 5.25 Coaxil Speakers Pair Rohs: Electronics
    or should i run the pioneers you recommend and
    Amazon.com: Pioneer TS-A1374R A-Series 5 1/4" 3-Way 300 Watts: Electronics
  7. #7 Re: 6x9s and door speakers
    Dec 2012
    Akron
    also does that amp have enough power for the 6x9s and door speakers?
  8. #8 Re: 6x9s and door speakers
    Jul 2012
    Chicago
    The Kickers don't have as good power handling as the Pioneers. I would still go with the Pioneers. As for door speakers, take these into consideration as well.
    Pioneer TS-A1304C (TSA1304C) 5.25" 2-Way Component Speaker System
    Being components they will sound better than the 3-ways. That's what I would do.
    I'm kinda a Pioneer/Polk Audio junky. I'll let others chime in about Kickers. I don't have much experience with the brand.
    Combined with your head unit, the amp will be more than enough power for the door and deck speakers. I don't know if you're crazy about bass, but with that amp and those 6X9's I don't think you'll be wanting a sub too much. At least for a while.. Haha.
    -Carl
  9. #9 Re: 6x9s and door speakers
    Dec 2012
    Akron
    Wow thank you for all your help I appreciate it and yea I might hold off I have a audioque 12 2.5 that still needs to be boxed and I still need to find an amp for it but maybe I will wait till spring thanks again for all your input ill let you know how the install goes let me know if you know any good amps for the audioque 12 2.5
  10. #10 Re: 6x9s and door speakers
    Jul 2012
    Chicago
    Hmm. I don't know much about subs. But I would try and find a good cheap 5 channel amp. My friend got a used Kenwood 5 channel for like $75. Works like a charm. That's what I wish I could have done, cause now I'm trying to get a sub into my setup for cheap. Browse around on Crutchfield and Sonicelectronix. Check out Diymobileaudio.com. Great car audio forums.
    -Carl
  11. #11 Re: 6x9s and door speakers
    Dec 2012
    Akron
    Alright once again thanks so much and should have the items shipped and installed within the next week ill keep you updated
  12. #12 Re: 6x9s and door speakers
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    What tweeters do you recommend?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  13. #13 Re: 6x9s and door speakers
    Jul 2012
    Chicago
    Quote Originally Posted by asite57 View Post
    I have these now.
    Pioneer TS-T15 (tst15) 3/4" Soft Dome Tweeters - Sonic Electronix
    I used to have these.
    Polk Audio db1001 db Series 1" Diameter / 25mm Silk/Polymer
    The Polks sounded great when you were playing them not too loud but when cranked they were too shrill for me. The pioneers are like my stock tweeters but a little clearer.
    -Carl
  14. #14 Re: 6x9s and door speakers
    Oct 2011
    Michigan
    I have these now.
    And they fit under the stock plastic housing fine? The tweeters I mean
    Aug 2011
    Kenosha
    I just put some alpine type s 6 1/2 speakers in my doors so they do fit in case your wondering. Just have to do a little tweaking.
    Dec 2012
    Las Vegas
    This was my fix for the 6.5" in an 04 door. ImageUploadedByTapatalk1356935597.989675.jpg
    Dec 2012
    Las Vegas
    Still keeps the factory rain gaurd and seals to the door panel like factory.
    6x9s and door speakers Attached Images
  18. #18 Re: 6x9s and door speakers
    Jul 2012
    Chicago
    Both the tweeters needed dremeling to fit. Not a big deal though.
    -Carl
  19. #19 Re: 6x9s and door speakers
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    wus the biggest size you can put in ya door speakers without any modifications? I swore 6.5" fitted perfically. I have a 00" Regal GS, so maybe the size is diff from a GTP. I thought they were the same actually...
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  1. Door speakers
    By maverickdog8 in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2012, 11:33 PM
  2. Door speakers...
    By Jordin in forum Audio, Security & Visual Electronics
    Last Post: 12-19-2011, 07:52 AM
  3. Aftermarket Door speakers
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 08-31-2008, 02:55 PM
