Thread: in-line amp wire fuse holder set screws
Results 1 to 11 of 11
  1. #1 in-line amp wire fuse holder set screws
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    So my in-line fuse holder to my AMP has lil set screws in which you use an allen wrench to screw down and make electrical contact with the power wire. i just noticed yesterday that my power wire is pretty loose and not sitting tight in the fuse holder like it is. ive been getting a lil static lately that ive never gotter before from my tweeters and 6.5"s/mids so im thinking this weak connection may be contributing to if not causing the static issue.
    Thinking about buying some allen head set screws that are a lil longer to make a better contact. Only problem is that I cant find no one who sells them locally and the internet acts like im typing in some foriegn word or something.
    Any ideas or suggestions of where I could buy these lil set screws to hold down the wire firmly?
    Thanks....
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: in-line amp wire fuse holder set screws
    Omaha, NE
    If it were me, I would replace the power wire completely.
    I don't see any reason you couldn't use a phillips or flat head screw instead of an allen...
  3. #3 Re: in-line amp wire fuse holder set screws
    GTP Level Member simbah's Avatar
    Lala land
    I would think that your local True Value or Ace hardware store will have what you are looking for.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  4. #4 Re: in-line amp wire fuse holder set screws
    SE Level Member 2000gtpbt's Avatar
    Mar 2012
    Alexandria, MN
    If you can't find what your looking for in screws, I'd look for a smaller fuse holder. But try fastenal they'll have what your looking for. Good luck.
    Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
    Albert Einstein
  5. #5 Re: in-line amp wire fuse holder set screws
    Yoga city
    And any noise is usally a ground problem, but it can happen with weak connections, either get a new kit or buy a new fuse block holder.
  6. #6 Re: in-line amp wire fuse holder set screws
    SWPA
    Fastenal. Take the screws in with you and they will be able to tell you what you need.
  7. #7 Re: in-line amp wire fuse holder set screws
    Jul 2012
    North Philly
    well, i could use anything that fits to screw them in but theyre specifically designed to be tighten down with an allen(6mm i believe). but the screws are fully extended, it use to fit firmly but now its loose like theres no conection at all. honestly, i wanna change the power wire anyway but im tryna keep a lil money in my pocket for awhile bc Xmas just killed my pockets
  8. #8 Re: in-line amp wire fuse holder set screws
    Omaha, NE
    I'm assuming that the screws are metal and the fuse casing is plastic. Over time, with a lot of use, and probably some overtightening, the plastic will expand and need to be replaced to get a tight fit.
    Alternately, you could use loctite, but thats probably going to be more of a bandaid than a real fix.
  9. #9 Re: in-line amp wire fuse holder set screws
    Jul 2012
    North Philly
    Yeah, the lil screws are like metal or stainless steel, I was looking for a better conducting socket set screw(preferably Copper since the screws are in direct contact with the AMP Power Wire itself)...Cant find any, best conducting/least resisting one I found was BRASS from Fastenal
    I do plan on installing a new fuse holder probaly this weekend...
  10. #10 Re: in-line amp wire fuse holder set screws
    Houston
    New fuse holder, definitely. Preferably an ANL fuse holder. And an amp to properly power those Morels.
  11. #11 Re: in-line amp wire fuse holder set screws
    Jul 2012
    North Philly
    My AMP is plenty(ZAPCO DC650.6 6channel)...And I just bought a JL Audio XB-MFBU-ANL Master ANL Fuse Block for 4 AWG to 1/0 AWG Power Wire with 25 Wire Entry/Exit Options
    AND a JL Audio XB-ANL150 ANL Blade Fuse: 150 Amp
    I Already had an ANL EFX fuse holder and EFX 150 amp fuse, the holder just had got ****ed up.....
    You think my AMP is ****ty or you think it'll be better to buy another AMP?
  1. Help me ID this line/tube/wire in the engine bay...?
    By Bjm5295 in forum General Tech Discussion
    Last Post: 12-19-2012, 01:07 AM
  2. Replies: 8
    Last Post: 10-28-2012, 03:58 AM
  3. headlight aiming screws...
    By villanex in forum General Grand Prix Discussion
    Last Post: 08-28-2012, 12:05 AM
  4. Engine Wire Harness/Fuel line
    By Spartan GL in forum General Tech Discussion
    Last Post: 04-27-2011, 07:17 PM
  5. ASAP!! Need to know Where the he!! does this line or wire go?
    By FlaminWhite97GTP in forum General Tech Discussion
    Last Post: 02-01-2010, 10:57 PM
