Thanks man. At idle with heater and radio on low volume the voltage under the hood matches back at the amp. 13.8 volts or so. Just making sure it wasn't a bad alt battery or ground since sears napa and interstate suggested these cars use a agm battery and that if you used a lead acid you would have voltage drop
