Thread: question about hooking subs up 99 grand prix gt.
Results 1 to 14 of 14
  1. #1 question about hooking subs up 99 grand prix gt.
    Nov 2012
    Alabama
    hey guys i was just wondering if a 99 grand prix gt has any sub woofer outputs
  2. #2 Re: question about hooking subs up 99 grand prix gt.
    GTP Level Member simbah's Avatar
    Lala land
    Depends on what kind of radio is installed.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: question about hooking subs up 99 grand prix gt.
    Nov 2012
    Alabama
    stock. just the reg cd player. no cassete
  4. #4 Re: question about hooking subs up 99 grand prix gt.
    No. But they make some amps that have a thing that you splice to the factory speakers wires and it plugs into the amp, this isn't the best way of doing it but if you have a factory deck its the only way to really doing it that I remember.
  5. #5 Re: question about hooking subs up 99 grand prix gt.
    Houston
    Quote Originally Posted by slick2500 View Post
    Thats a high level input. You'd want to go with a LOC and some RCA's if you plan on keeping the stock deck for a while. But it's gonna sound like chit if you're looking for any kind of sound quality. The bass is gonna sound loud at low volumes and weak at high volumes. It'd be best to go with an aftermarket deck so you can control the subs separately.
    GT Level Member maverickdog8's Avatar
    Bettendorf, Iowa
    That is by far the worst way of doing it. Just swap you deck out or leave it stock. When you put that converter box in it sucks power from you speakers to give power to the amp. You also have to find a way to place the remote wire. When you hook to the speakers it starves your amp for power which is horrible for it.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Just go pick up any aftermarket deck with an RCA out .
    Btw you will lose steering wheel controls
  8. #8 Re: question about hooking subs up 99 grand prix gt.
    SE Level Member Gm Man's Avatar
    Oct 2012
    Elk Grove, California
    Quote Originally Posted by Kolton Lock View Post
    I agree lose the stock deck buy a aftermarket deck, gm stereo harness($5.99) make sure to connect the pink wire from the small red harness to the remote wire (blue/white), gm antenna adapter($4.99, mounting kit ($10) from ZZPerformance. Replace the speakers to, it will sound so much better. I put a Alpine deck with 3 RCA preouts, 240 watt 3-way 6.5" Kenwood in the front, 270 watt 3-way 6x9 Pioneer in the back connected to a 600 watt 4-ch Kenwood amp, 140 watt 2-way 4" Alpine type S to the stock bose amp and two 12" subs wired in series bridged to a 1000 watt Kenwood amp, Big 3 upgrade, 2000 watt 2 farad capacitor, it sounds great I love it, my brother-in-law can't stop talking about how he wants to do the same to he's GP. If you want to take a look Click my Grand Prix cardomain link below.
    1973 Cadillac Coupe Deville: http://www.cardomain.com/ride/400873...illac-deville/
    1983 Chevrolet Camaro Z28:
    http://www.cardomain.com/ride/400874...vrolet-camaro/
    2000 Pontiac Grand Prix
    GTP: http://www.cardomain.com/ride/400874...-gtp-sedan-4d/
    Quote Originally Posted by Mac Dre of Thizz Nation
    I need cash, Like a car needs gas
    I live here. DirtDog's Avatar
    Jun 2012
    I agree with new deck install. If u wanted to keep the deck stock u would have to use line
    Sent from my DROID RAZR using Tapatalk 2
    Jun 2012
    I agree with new deck install. If u wanted to keep the deck stock u would have to use line output converter. I've used em before and they definitely don't have the best sound quality. For the remote on switch a 12 volt source and a cheap on off circuit switch from parts store under ur dash or something. Its simple. I have something similar for my auxiliary in adapter
  11. #11 Re: question about hooking subs up 99 grand prix gt.
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    You can also buy a steering wheel control adapter where you can use your steering wheel to still be functional with the after market deck.
  12. #12 Re: question about hooking subs up 99 grand prix gt.
    SE Level Member bustaphoto's Avatar
    Oct 2016
    Miami
    Do you guys have any experience with a specific control adaptor? Any links?
  13. #13 Re: question about hooking subs up 99 grand prix gt.
    Aug 2016
    CT/RI Border
    Honestly if you haven't had much personal experience with car audio installation I'd advise finding a reputable local installer.
    https://www.crutchfield.com/S-iePrO3...-Adapters.html
    If you are willing to tackle it yourself, check for compatibility with the stereo you install.
    Sent from my ASUS_Z00TD using Tapatalk
  14. #14 Re: question about hooking subs up 99 grand prix gt.
    SE Level Member smg267's Avatar
    Apr 2016
    killadelphia
    https://www.amazon.com/PAC-SWI-PS-In.../dp/B001EAWNVY
    I used the PAC-SWI and retained the use of my stereo controls. You need to make sure that the new headunit has a wired remote plug in the back. 99% of new headunits will have this feature by default. The only other step was splicing into one wire on the factory harness with The PAC interface. The unit self programmed for me and installed in less than 15 minutes.
    99 GTP , 01 Z/28 H/C/I , 05 Hemi Grand Cherokee, 07 Ducati S2r800
  1. Wiring Subs in 2002 Grand Prix
    By RedGT34 in forum Audio, Security & Visual Electronics
    Last Post: 08-18-2012, 08:29 PM
  2. Need Help Installing Subs in 05 Grand Prix
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2012, 03:03 PM
  3. need help wiring subs in 99 Grand Prix
    By asite57 in forum Audio, Security & Visual Electronics
    Last Post: 02-13-2012, 11:17 PM
  4. '88 grand prix question
    By xclukx in forum General Tech Discussion
    Last Post: 05-19-2010, 07:52 PM
  5. Question about stock subs
    By wildmn26 in forum Audio, Security & Visual Electronics
    Last Post: 04-07-2010, 11:31 PM
