Thread: 04+ Sub help!
Results 1 to 20 of 20
  1. #1 04+ Sub help!
    Jun 2011
    I would like 2 subs in the trunk w/ a box.
    I do have monsoon with an touch JVC unit.
    Not sure if i my back speakers would work with and aftermarket amp...
    Could i run 2 amps? 1 amp just for subs. Any suggestions?
    To summarize i would like suggestions for these:
    Nice box for 04+'s
    12" subs
    amp
    Budget is 0$-800$
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    If you have monsoon I wouldnt bother replacing it with a 4ch.. its already a 500watt amp if I remember correctly.
    Sub amp should be easy since you already have a jvc headunit. Just run a set of rcas.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: 04+ Sub help!
    GTP Level Member simbah's Avatar
    Lala land
    Your Monsoon amp is a whopping 270 watts of total power for 9 speakers. Your JVC HU is probably more powerful without an amp, so yes I would replace the Monsoon amp with a better quality 4 channel and separate mono block amp for the sub, of course along with all new speakers all around. You will be more satisfied in the long run, trust me I have already done this.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
    Oct 2011
    MI
    Wrong. Any aftermarket cd player is around 15-20 watt rms. 50 watt peak is usally what you see.
    I know the trans am monsoon amps were 500 watts. im not sure exactly on the 04+ though 270 seems a little low considering the amps are similar in size.
    Besides monsoon vehicles have a center dash speaker powered by the amp
  5. #5 Re: 04+ Sub help!
    Yoga city
    ok gm claims there is different ratings but the monsoon only powers the sub stage, tweeters are ran from the deck. All monsoon amps if you open them up there idendical boards so all there ratings seem sqewed to me. Since you have a after market run your rca's to just your amps and speakers you want to amp. i left my center channel on the rear amp. .
    budget , you wanna save alot or be near that 800$? i can make a couple list up easily. In your budget you can find a nice setup
  6. #6 Re: 04+ Sub help!
    Northeast Ohio
    i have re-done my whole audio system in my car to be honest the monsoon system is a joke and those paper stock speakers are as well in the end it depends what your looking for if you want just a little more or are you looking for a loud with sound quality alot is to be determined before i could help....so 1. what exactly are you looking to get out of your system 2.how much are you looking to spend
    Oct 2011
    MI
    The monsoon amp powers every speaker in the car what the hell are you talking about... im looking at a diagram right now
    Also saying a monsoon speaker is cheap paper is like saying a bose speaker is cheap. There is plenty of engineering that goes into a monsoon or bose system. Doesnt matter what they are made of.
    Majority of aftermarket **** wont sound nearly as good because most people cheap out on buying quality aftermarket equipment. But good luck on that
    Btw our shop specializes in factory sound.
  8. #8 Re: 04+ Sub help!
    Yoga city
    all channels run through the amp to get the signal for the sub,
    Oct 2011
    MI
    All the speakers are powered by the amp. Period.
    I guess im at a lose to what point your even trying to prove.
    The amp gets the input signals from the radio. The amp then turns signal into the proper outputs..
  10. #10 Re: 04+ Sub help!
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    op, any particular reason you want two subs?
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
  11. #11 Re: 04+ Sub help!
    Jun 2011
    Thanks for the replies.
    Why not 2 subs? Should i just run 1?
    Im looking for a decently loud system w/ bass.
    Im not really on a budget, but i dont want to OD it or cheap out.
    For those of you gen 7 monsoon guys... what are you running?
    Oct 2011
    MI
    I left my Monsoon alone and added a single Type-X Alpine 12" in a slotted port box. Powered by an alpine pdx m6. Its loud enough for me. One can always go further with the highs but ive got a 4yr old and have been tempted lately to sell it just because the sub turned off majority of the time anyways. Im getting old I suppose.
  13. #13 Re: 04+ Sub help!
    Dec 2010
    ATL,Georgia
    If your looking for a good sound system then scrap the Monsoon all together... replace the front doors with components, center speaker, and the two rear 6x9's( you could do 6x9 components too if you are feeling optimistic), then get a 4 or 5 channel amp to run the speakers and then either 1 or 2 subs with a mono amp... it will be 10x better then the stock system believe me.
    Polk, MB Quart, Infinity, Rockford are all good and decently priced... people will go back and forth for ever on which brands are best.. it is all up to you and what you think sounds better imo... i have heard some good and bad systems with all the top brands..
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
    Oct 2011
    MI
    Quote Originally Posted by Alix0r View Post
    Aint that the truth. :banghead:
  15. #15 Re: 04+ Sub help!
    Sep 2011
    Vancouver
    Quote Originally Posted by E IN v Y View Post
    depends on your goals. But 2 subs= more weight, more money, more space
    EDIT- assuming the same size sub of course.
    99 R34 skyline
  16. #16 Re: 04+ Sub help!
    Jun 2011
    Im looking at this:
    Pontiac Grand Prix 2004 08 Subwoofer Sub Box Enclosure | eBay
    Im thinking of keeping the monsoon for now and adding a second amp for the 2-12".
    What would you guys suggest if i went this route?
  17. #17 Re: 04+ Sub help!
    Northeast Ohio
    im running focal all the way around for the indoors powered by an infinity 475a 4chan i also have 2 alpine type rs 12s in a ported box running on a alpine mrp-m1000 down to one ohm, i have a pioneer 6200bt head unit, im running a optima yellow top up front and a kinetik 1400 in the back sounds great super clear and beats damn good
    It's best to avoid the prefabbed boxes and have a box made but a local audio store to the specs of the subs. Shouldn't cost much more than what that box on eBay is selling for if not less and will sound 10x better.
    04 Comp G.
  19. #19 Re: 04+ Sub help!
    Northeast Ohio
    very much agreed also look into birch its more expensive but alot lighter and sounds alot better, and if you get a custom built box have all corners 45ed
    Jun 2011
    Thanks for the tips.
    Sent from my Samsung Galaxy S3
