Thread: Car keeps dying while heat is on
Results 1 to 9 of 9
  1. #1 Car keeps dying while heat is on
    Minnesota
    I want to get this fixed before Winter comes for obvious reasons:
    I have a 2002 Monte Carlo and it keeps dying when coming to a stop only while the heat or AC is on. Basically any time I have the air blowing out of the vents it will die when coming to a stop. I can see the voltage drop when I come to a stop also. It's almost like the car is drawing too much for the alternator to keep up.
    First thought was alternator which I ended up getting a sweet deal on a 220amp DBelectrical one off here. I have yet to intall it.
    Second was the ignition switch.
    Any other ideas? I will be installing the alternator this week.
    Here is a video too:
  2. #2 Re: Car keep dying while heat is on
    It does sound like charging system related.
  3. #3 Re: Car keep dying while heat is on
    Pennsylvania
    On my 95 explorer, the voltage meter was dropping sharply to the point where it wasnt safe to drive at night, because having the lights + heater on was dropping the voltage way too low and it was almost stalling. If it was raining and I needed the wipers, forget it.
    I replaced the belt, cleaned up the battery terminals and reseated the alt connections and it got way better.
    Sport Edition Kv5 18x8
  4. #4 Re: Car keep dying while heat is on
    Sep 2011
    MI
    I would turn on everything but the heater(wipers, radio, headlights, ect...) to see if it is a electrical issue. Those other systems should pull as much as the blower.
    Are the heater controls vaccume operated? Could be leaking through the heater control...
  5. #5 Re: Car keep dying while heat is on
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    battery is weak do a crank voltage test if volts drop below 9 its the battery
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  6. #6 Re: Car keep dying while heat is on
    What I read.
    Guys, I'm having a voltage issue, bought the parts and well.. just letting you guys know.
  7. #7 Re: Car keep dying while heat is on
    the fan quits working or the engine stalls?
    if it stalls i would think the a/c compressor is going bad. it works when the heat or a/c is on.
    if the fans quitting i would test the alt and battery.
  8. #8 Re: Car keep dying while heat is on
    Scott..he said ign volts are dropping with fan on, and he figured out the regulator is likely bad. So he's got an alt sitting there about to go on.
    This is a info only thread...he's not looking for help yet.
  9. #9 Re: Car keep dying while heat is on
    Minnesota
    What I read.
    Quote Originally Posted by Pure2sin View Post
    Negative Nancy. lol
    I think it might be due to the fact that I also have both fans coming on at the same coolant temp in my file. We will see.
  1. engine dying
    By Leah and Justin in forum General Grand Prix Discussion
    Last Post: 08-03-2012, 09:13 PM
  2. Car dying in heat, not overheating
    By Tony Smith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2012, 04:21 PM
  3. Battery keeps dying...........PT 2
    By mallard22 in forum General Grand Prix Discussion
    Last Post: 05-11-2012, 11:30 PM
  4. 01 gt dying a lot
    By Cummins97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2011, 09:18 PM
  5. Car keeps dying
    By jakeeck in forum General Tech Discussion
    Last Post: 02-19-2009, 12:26 AM
