Thread: Key stuck in ignition, won't start, won't shift out of first park !!.
Results 1 to 5 of 5
  1. #1 Key stuck in ignition, won't start, won't shift out of first park !!.
    Apr 2009
    Ohio
    I have a 98 GTP
    Just like the title says, My key is stuck in the ignition, will go back as far as the normal off, but won't come back to where i can release it. It will not shift out of park (the button won't even push in on the shift lever.) And it will not start, even though I can push the key back in to the start position.
    I have a Viper car alarm remote start hooked up. I was trying to replace my supercharger smooth pulley and put a new belt on, I heard a pop. So I'm assuming that something shorted out, everything else seems to work fine, and when I push remote start from my phone, it will start the car. I'm not sure if this is the right place to put this thread, but I'm really thinking it's something to do with either the factory security system or the viper one.
    Please help with any ideas you might have, dead in the water right now.
  2. #2 Re: Key stuck in ignition, won't start, won't shift out of first park !!.
    check the cables off the battery and any in line fuses you can find for the alarm.
  3. #3 Re: Key stuck in ignition, won't start, won't shift out of first park !!.
    Sep 2012
    chicago
    All of them have something with the factory security to where if the battery is dead you cant take the key out or shift out of park i would check all fuses and see if any are bad sounds like that portion of the ignition lock isnt getting power
  4. #4 Re: Key stuck in ignition, won't start, won't shift out of first park !!.
    GT Level Member GRAFIX's Avatar
    Chicago, IL
    Check out my thread. I found the solution and fixed my problem with the key getting stuck and shifter not shifting out of park.
    http://www.grandprixforums.net/key-s...ark-58434.html
    hope this helps!
    2000 Mustang GT -
    Member's Page - (Current)
    2002 Grand Prix GT - Member's Page - (Sold)
  5. #5 Re: Key stuck in ignition, won't start, won't shift out of first park !!.
    Texas
    You can get your keys out of the ignition. All you need to do is move the little plastic cover under the steering wheels and shove a screw driver in it. I keep a philips head screw driver in my car for this very reason.
    85 Corvette
    01 TA
    03 Z06
  1. Key stuck and car won't shift out of park
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2012, 11:47 PM
  2. Car won't move out of park and key stuck in ignition
    By kc199 in forum General Tech Discussion
    Last Post: 03-20-2012, 04:41 PM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. Won't Shift Out of Park (sometimes)... Ignition Switch?
    By GTFiske in forum General Tech Discussion
    Last Post: 01-12-2011, 12:53 PM
  5. Car won't move out of park and key stuck in ignition
    By DanGTP in forum General Tech Discussion
    Last Post: 10-09-2010, 03:46 PM
