Thread: cant read cd's
Results 1 to 12 of 12
  1. #1 cant read cd's
    GT Level Member sirricealot's Avatar
    Sep 2012
    Mascoutah IL
    My 08 gxp wont read a burned cd. is this normal? I really hope I dont have to have all non burned cds or switch the head unit out... too much $..
    If there was a way to get an AUX on mine i'd be fine.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Are you burning on CD-R, or CD-RW? RW has a lower contrast and can cause playback issues.
    Also the program you're using could be an issue. I recommend iTunes.
  3. #3 Re: cant read cd's
    Sep 2012
    Mascoutah IL
    I was using a RW and Itunes. Ill try a cdr thanks
  4. #4 Re: cant read cd's
    I've had this problem before and swapped cd brands and all was well
  5. #5 Re: cant read cd's
    Kansas
    Media material, speed its burned, quality of audio track, format it's burned in are all factors.
    Plus I would recommend something other than iTunes for ripping and burning audio discs.
    Only cause I hate Apple... well not fully, but there are better applications.
    Mar 2012
    Minneapolis MN
    Quote Originally Posted by NegativeOne13 View Post
    There are, but that's the only one I used before I just got a Bluetooth deck lolol
  7. #7 Re: cant read cd's
    Sep 2012
    Mascoutah IL
    Well I got the CDRW from walmart and it didnt seem to work at all in the GXP. So I'm gonna go get a 5pk of CDR and see if that works. I've had some of my old CDR work but I need more. Just sucks not having an aux port now.
    Mar 2012
    Minneapolis MN
    I would recommend Memorex. They've been a good solid brand for me. Back when I had the $1000 Clarion from 99 in my GP. Would only play Memorex CD-R
  9. #9 Re: cant read cd's
    Sep 2012
    Mascoutah IL
    Quote Originally Posted by Kolton Lock View Post
    Thanks i'll see if i can find some. REally wish there was a freakin AUX port! I can't listen to pandora anymore without using a pos fm transmitter.
    And I know the PAC harness for aftermarket radios are not cheap or easy to use.
  10. #10 Re: cant read cd's
    The Axxess kit is usually easier than PAC.
    iTunes can burn CD's.. wow, didn't know that. Always used media player etc. Quick, easy and done.
  11. #11 Re: cant read cd's
    Sep 2012
    Mascoutah IL
    CDRs worked! Now I just gotta look into the AUX port mod on the XM harness.
    Mar 2012
    Minneapolis MN
    Glad to see it worked for you
  1. Please Read
    By webracin in forum The Rant Forum
    Last Post: 07-18-2015, 02:03 AM
  2. Hi Everyone! Please read..
    By ToXiC in forum Off Topic Discussion
    Last Post: 11-23-2010, 09:13 AM
  3. A Must Read
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 05-31-2009, 11:51 AM
  4. Please read!
    By SlowM90 in forum Off Topic Discussion
    Last Post: 04-01-2009, 12:20 PM
  5. *please read*
    By JCG's-GTP in forum Track Sessions and Kills
    Last Post: 03-01-2009, 11:36 PM
