Thread: No Start - - key was stuck - No Lights except for oil and door open
Results 1 to 2 of 2
Eric Downing No Start - - key was stuck - ... 09-15-2012, 01:16 PM
FordMan77 Re: No Start - - key was... 09-15-2012, 01:19 PM
  1. #1 No Start - - key was stuck - No Lights except for oil and door open
    Apr 2012
    I went to start my 2001 Grand Prix and the key got stuck and it would not start. I got the key out but the the motor would not turn over and I don't have any dash lights except for the door open and oil light. These two dash lights are dim.The horn is is not loud and does not sound normal. The horn is so quiet is is almost hard to hear. The headlights and no other lights work. The power locks make a small chirping sound that is coming from under the driver side floorboard. It will not come out of park unless I push the shift release.
    The battery tested okay and I replaced the ignition. What should I test next?
  2. #2 Re: No Start - - key was stuck - No Lights except for oil and door open
    St. Louis
    Check the cables at the battery. Sounds like a corroded/loose connection. Don't just "look" at the cables, physically try and move them. If loose or dirty then clean them up and retighten.
  1. HELP-hood latch stuck open
    By fst in forum General Grand Prix Discussion
    Last Post: 01-19-2012, 12:33 PM
  2. Door Signal stuck open on DIC
    By thunder71173 in forum Audio, Security & Visual Electronics
    Last Post: 01-18-2011, 07:39 PM
  3. sunroof visor stuck open
    By hourang in forum General Tech Discussion
    Last Post: 06-30-2010, 04:42 PM
  4. EGR is stuck in open
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 10:32 AM
  5. stuck in open loop and LTFTs pegged at 0.0%
    By fst in forum PCM Tuning
    Last Post: 05-02-2008, 08:57 AM
